Motor has A TICK... Thoughts?
I have a 72 blazer with a pretty well built 350. It has recently developed a ticking noise. At first it came and went. This last time out we went 15 miles on light trails and when we finished the tick was persistent. In the same little trip I developed some smoke coming from the drivers side only. Same side tick is heard.
The smoke is does not smell like oil and I know it is not coolant, it also smells like a motor running a little rich. So what are your bets? I am thinking about trying to DIY, but I have the head off my jeep now and am replacing the cam on it, it has taken longer than it should. This might go to the shop.
Confidence is the feeling we have before we fully comprehend the situation |
![]() Join Date: Oct 2007
Re: Motor has A TICK... Thoughts?
Lifters ? Pour a small amount of tranny oil down the carb and see if that makes it go away.
I have heard of pouring a little tranny oil into the oil.
try some of this.....
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
sorry but I had to do it.
i have a tick on my eclipse and i found its the lifter.. like stated id try some of the tranny fluid.. the eclipse runs fine and its got 130,000 miles so i havent felt like fixing mine yet
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
are you sure its not an exhaust leak?those donuts make a ticking when they rot out// tried torqueing the exhaust manifolds ?
i wouldnt use tranny fluid, MARVEL MYSTERY OIL is the stuff for lifters if that is in fact your problem
![]() Join Date: Aug 2001
THAT FLEA & TICK SPRAY WAS PRICELESS.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I would check for an exhaust leak around the manifolds or headers.
Is the smoke coming from the exhaust pipe or the engine compartment? I would also use Marvel Mystery Oil. That's what my pops would use. You need to loosen up and clean out those hydraulic lifters since they might be stuck and all gummed up inside. After running that Marvel Mystery Oil through it, might want to adjust the valves as well with the engine running. That's the best way. Also, turn the push rods to free them up and loosen any gunk that might be in them.
