Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-07-2010, 12:50 AM   #1
wendling053
Best turbo
Whats the best turbo to use I am going single turbo on a 350 tbi what would be the best turbo to use with out lag and most power gains on pump gas?
wendling053 is offline   Reply With Quote
Old 06-07-2010, 12:55 AM   #2
Terry'sToy
Re: Best turbo
a friend built a 302 and used a single HX35 with a 14" exhaust housing from a 5.9 cummins. It ran high 11's.
But how do you plan to tune this?
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
Old 06-07-2010, 07:23 PM   #3
wendling053
Re: Best turbo
My buddy has a shop call proven power he said if I build it he can tune it
Old 06-08-2010, 12:00 AM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Best turbo
How deep are your pockets? Are you talking new turbo or one from a used vehicle?
prostreetC-10 is offline   Reply With Quote
Old 06-08-2010, 12:19 AM   #5
wendling053
Re: Best turbo
Well I know there are kits out there to do it but it make me feel better knowing I built the whole setup, I just need to know what turbo works best on a 350
t3/t4 or would I need something bigger?
Old 06-08-2010, 12:26 AM   #6
wendling053
Re: Best turbo
Would this turbo work?
http://tampa.craigslist.org/hil/pts/1778354514.html
Old 06-08-2010, 03:28 AM   #7
8mpg
8mpg's Avatar
Re: Best turbo
HX35 is a decent size turbo... just watch out. That thing will put out 30+psi without a problem. Most gas motors wont even come close to holding that.
HX35 can be picked up cheap though. If you are looking to use a diesel motor, also check out the HE341s off a 03-04 Cummins.
8mpg is offline   Reply With Quote
Old 06-08-2010, 08:52 AM   #8
prostreetC-10
My Carbon Footprint
Re: Best turbo
There is a funny post on the main forum about what BS people say when trying to sell their vehicles. I think the biggest thing with a used turbo is if it really is what they say (condition wise) or if it will need to be completely rebuilt.
Old 06-08-2010, 02:09 PM   #9
Alex1
Alex1's Avatar
Re: Best turbo
OK -save some money and buy a new Precision turbo. Speak to a shop that deals with this stuff and tell them exactly what you want. Junkyard specials are great, but you can get a bran-new 76mm Precision for like $1100.00 (even cheaper if you look around)
No t3's, minimum one or two t4's or a t6 if you go BIG power 91mm +
I's not like bolting on a blower. A properly sized turbo (with a propely set up engine etc..) will spool quickly and not choke on the top end. I'm not talking race stuff though - that's completely different.
Good luck.
Alex1 is offline   Reply With Quote
Old 06-08-2010, 10:08 PM   #10
wendling053
Re: Best turbo
But wont a t3/t4 spool quick I dont care about how long it will last or anything Im going to be replacing the motor with a built 454 any ways I just want to see how much I can squeeze out of the 350 before it pops for the cheapest price
Old 06-08-2010, 10:11 PM   #11
wendling053
Re: Best turbo
what about a t25?
Old 06-08-2010, 10:53 PM   #12
Schralper
Schralper's Avatar
Re: Best turbo
Originally Posted by wendling053 View Post
what about a t25?
check out this for the d-lo on turbo's
http://www.theturboforums.com/smf/index.php
sweet setup i'm considering
http://wrenchrat.com/twinturbo/
if single think like 70mm
Schralper is offline   Reply With Quote
Old 06-09-2010, 01:01 AM   #13
atopper
box junkie !!
atopper's Avatar
Re: Best turbo
Master Power 70 or a borgwarner S400
- 500mg of crazy a day ...... will keep the straight jacket away !!! :burno
atopper is offline   Reply With Quote
Old 06-09-2010, 10:13 AM   #14
Alex1
Alex1's Avatar
Re: Best turbo
Spool quickly, probably, and choke the motor at 4000rpm if you only use one. If its just to fool around then try it. certainly if you just plan on using a stock 350.
I bet you could get properly sized Precision or Turbonetics to spool just as quick and hit a hell of a lot harder and have a nice top end - and it would easily walk a 500hp 454!
Old 06-09-2010, 02:35 PM   #15
bigsnookmaster
bigsnookmaster's Avatar
Re: Best turbo
Nitrous is cheap and easy!
bigsnookmaster is offline   Reply With Quote
Old 06-09-2010, 03:00 PM   #16
Wild83C10
Wild83C10's Avatar
Re: Best turbo
Best bang for the buck would be a Master Power T76 for a stock type 350, but would suck on a 454. In order to properly size the turbo you need your horsepower goals then calculate how much air you need and look at a compressor map.
Putting a custom turbo kit together isn't all that easy, but if you do your research it wont be that hard. I have been assembling all of my parts for about 8 months now and I am almost finished with mine. I have watched for deals and bought new stuff from other forums (new parts that guys have sitting around because they changed their mind). I still have about $2500+ into my setup, that includes a $400 S475 and I am doing all the work myself.
Don't forget to upgrade your fuel system.
I think you should read Maximum Boost by Corky Bell before you go buying a turbo. Not to insult you or anything but your knowledge of turbos sounds very very limited.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 06-09-2010, 07:21 PM   #17
Alex1
Alex1's Avatar
Re: Best turbo
agreed, don't take it as an insult. Turbos require a bit more research - the outcome of a well designed system is well worth the effort!
you don't want to be the guy selling his stuff for dirt cheap because you bought the wrong thing...you want to be the guy buying the stuff that's dirt cheap from the guy that bought the wrong thing...lol
Old 06-09-2010, 07:40 PM   #18
atopper
box junkie !!
atopper's Avatar
Re: Best turbo
i agree with Wild and Alex.
just to slap somethin together and hope it works is a major shot in the dark with a turbo setup. do your research and read read and read some more . turboforums.com is an over flowing website of turbo info. you name it , its prolly there. alot of guys went thru alot of trial and error to come up with some good info and to help new comers from makin $$ pricey mistakes.
soooo if your serious about goin TURBO , do your research. read !!! and us the search button. they even have a newbie section and a chevy section. if ya just wanna slap a turbo on quick and make big power , forget it if your not knowlegdable about turbo systems and how they work.
Old 06-20-2010, 09:24 PM   #19
wendling053
Re: Best turbo
it is i just spray the **** out of what ever I have always have, have never been under a 200 pill on anything I have ever sprayed on, if it blows up it blows up.
just wanna go a different route on this truck, want to see how much boost I can get on a stock 350 before I build the truck now I am working on collecting all my parts for the body new doors, cab corners, new dash, carpet and so on....I am a body man by trade yeah i know enough to get me by when it comes to motor wise, but im new to boost
Old 06-21-2010, 10:48 PM   #20
Wild83C10
Wild83C10's Avatar
Re: Best turbo
Read through this thread. Guy ran 9.30s at 150 with a stock junkyard 350. If the tune is right you will blow up the tranny or rear before the engine goes. I have seen a few cars/trucks run 9s with a stock 350 block and a turbo (BW S480 to be specific). It's all in the tune though.
Read through theturboforums for a ton of good info.
turbo=
Old 06-22-2010, 12:16 AM   #21
atopper
box junkie !!
atopper's Avatar
Re: Best turbo
Old 06-22-2010, 03:06 PM   #22
Shon
Re: Best turbo
not sure how he is going to tune the 350TBI, it can be done but it not fun.
but getting the correct turbo on it will mean alot more than just picking one and hoping it works.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-05-2010, 09:28 PM   #23
ZombieWeinerDog
ZombieWeinerDog's Avatar
Re: Best turbo
Garrett 38r!
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
