Old 06-07-2010, 01:34 AM   #1
dnorris009
dnorris009's Avatar
Inline 6 headers installed...Now it won't stay running
First, I wanted to say thanks for all the help.
This is a great community, especially for me...the mechanically challenged.
Anyway, My 200 inline chevy never failed to start & idled fine with the stock exhaust manifold. (even with manifold only/no pipe)
Installed the longtube headers & now it refuses to stay running.
If I keep feathering the gas, I can keep it running
but the minute I let off, it dies.
Only thing I've done was change from stock exhaust to headers.
Does going to headers require changing the timing? Carb adjustment?
Something else I'm missing?
Thanks again for any help.
Dave
dnorris009 is offline   Reply With Quote
Old 06-07-2010, 02:02 AM   #2
caja_larga
Re: Inline 6 headers installed...Now it won't stay running
I would say intake leak. Are you running a stock intake? dis you install new gaskets?
caja_larga is offline   Reply With Quote
Old 06-07-2010, 02:25 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
First make sure you don't have an intake leak by taking carb cleaner/WD40 or anything else flammable and spraying around the intake. If your engine speed increases you have a leak. If not your carb is in need of adjustment. Your Idle/air mix screw is located at the front base of the carb. Open it about 1/4 turn and try it. You may need to adjust your idle speed also. Hope this helps.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-07-2010, 07:10 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
"200" ?
Anyway, manifold leak X3.
Old 06-07-2010, 09:32 AM   #5
junkyardjohn
junkyardjohn's Avatar
IT WOULD BE QUITE A COINCIDENCE FOR THIS PROBLEM TO POP UP OUTA THE BLUE. EXHAUST CHANGES WONT HAVE ANY EFFECT ON THE PROBLEM YOU DESCRIBE. THEREFORE IT MUST BE SOMETHING YOU INNADVERTENLY DID DURING THE HEADER INSTALL. (BUMP A WIRE OFF, ? REMOVE THE CARB? CHANGE THE TIMMING? ECT.) THINK BACK & RETRACE YOUR STEPS. WHEN YOU HEAR HOOFBEATS.. DON'T LOOK AROUND FOR UNICORNS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-07-2010, 11:47 AM   #6
Old Bluey
Old Bluey's Avatar
It happened to me the 1st time I did an intake swap (vacuum leak) . I traced it back to an uneven torque on the intake/exhaust bolts. I tightened a couple down and it misaligned the manifold enough to keep it from sealing.
Staggering the bolt pressure is key when cranking it down.
Old Bluey is offline   Reply With Quote
Old 06-07-2010, 11:52 AM   #7
dnorris009
dnorris009's Avatar
200? Oops, Thinking of my old Ford it's a 250
Thanks.
First thing I'll do is check for an intake leak after work.
Old 06-08-2010, 09:56 PM   #8
292farmer
292farmer's Avatar
u may need to adjust the idle if it isn't an intake leak. i know i needed to do a little adjusting, headers seemed to make the idle go lean on my 292. (or i hit it pulling the carb off)
292farmer is offline   Reply With Quote
Old 06-09-2010, 01:44 AM   #9
dnorris009
dnorris009's Avatar
Hey Farmer,
After reading the advice here (Thank you everyone)
& looking at the pictures you shot for me of "The Beast's" set-up. I'm pretty dang sure it's an intake leak because
I used studs that aren't long enough to use the intakes original clamp point.
I used the lower lip & think that's not good enough.
Going to mimic your set-up & see if that fixes it.
By the way,don't know how you got away with runnin' open headers so long.
Mine is LOUD as hell & sounds like a machine gun
Old 06-09-2010, 06:05 AM   #10
292farmer
292farmer's Avatar
lol yes they are loud, makes u think u can compete with a pulling tractor the cops in my area could give a crap for a truck with no exhaust, hell my town cop has pulled me over doing 85 in a 30 and all i've gotten is a verbal waring.
Old 06-11-2010, 06:36 PM   #11
292farmer
292farmer's Avatar
did u get it running right?
Old 06-12-2010, 11:28 PM   #12
dnorris009
dnorris009's Avatar
Yes,finally.
She's Alive!!!!! {insert maniacal laughter}
Click on the engine for the video.
Ain't no way I could drive around like this.
Was scaring little children & setting off car alarms when I opened her up
during the test drive
Old 06-12-2010, 11:52 PM   #13
usmcchevy
usmcchevy's Avatar
So.......What was the problem? If ya don't mind me ask'in.
Build thread
LSx Swap FAQ index
Old 06-13-2010, 01:04 AM   #14
dnorris009
dnorris009's Avatar
Well basically, My head was up my butt.
The new studs I installed weren't long enough for two of the stock intake clamping points.
So I tried using the lower lip but that caused a major intake leak.
My original plan was to use a 1 to 2 barrel adapter with the stock intake I had from a previous project.
Gonna have find something better though,or install an aftermarket intake, because the way I've got it now is far from perfect.
Old 06-13-2010, 03:13 AM   #15
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Ever since i added headers to my 71 longhorn 350, it's been nothing but headaches!
never again.
the worst part is, the ram horns were just fine.
Mr. murphy made an appearance on that one LOL
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 06-13-2010, 03:17 AM   #16
'68OrangeSunshine
Just a thought here... Are you still using the stock guide pins on the ends? The ones outside of the port for cylinders 1 and 6? Guide pins won't work with headers. They can be removed with a vicegrips and PB Blaster and spun off CCW. The holes are threaded 3/8-16 UNC. I use a stud 3/8-16 --3/8-24 in holes 1 and 8.
