![]() Join Date: Aug 2009
Bilstein shock help needed
I want to install Bilstein shocks in the rear of my '72 C10 Fleetside (with leaf springs). Problem is Bilstein doesn't have a rear fitment for this truck. They have to have a shock that would work. Anyone know of a part number that would fit?
Blayne |
motor exploder
Re: Bilstein shock help needed
I'm pretty sure CPP offers a Bilstein shock for the rear of our trucks. Hit up Jeff Norton from Classic Performance Products (screen name CPP Jeff) he'll be able to help you for sure. He usually hangs out in the suspension forum.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
CPP and others carry a bilstein replica of the factory shocks and are $90 a piece. A straight bilstein is about $70 a piece. I'd rather save the $20 a shock and try and find the bilstein branded shocks.
Blayne |
The shocks CPP sells are designed by Race Car Dynamics and then built by bilstein. i have them on the front of mine and i will soon be buying them for the rear.
there should be a bilstein out there that fits. call RCD and talk to them, they should be able to find you the right shock. http://www.racecardynamics.com/class...ag/airride.htm |
Active Member
Blayne,
Digging up the past, however did you ever come across a part # for the rear coil spring suspension Bilstein shocks? Do either Bilstein part #s 24-002486 or BST-55-R034 ring a bell? Thanks, -Fred
"The Great State of Florida" |
not sure about the right one for your truck, but one of the folks in here steered me here for a good price and fit for my '70.
http://www.shockwarehouse.com
Figure out what you want--then figure out what you are willing to give up to get it. |
http://www.shockwarehouse.com/site/p...rucks-and-SUVs
This site gives a different part number the what you listed KFreddy
Blayne |
Give RCD a call, great bunch of guys. They will be able to recommend a bilstein shock for whatever your application.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
