Old 06-07-2010, 10:55 AM   #1
sixbangr
sixbangr's Avatar
which 235?
'61 235. looks like they made 3 different ones. Any way to tell without the valve cover decal?
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 06-07-2010, 11:02 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: which 235?
Get the casting number off the passenger side of the block. Raised letters, usually around the starter. Then go to www.inliners.org and look under casting numbers.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-07-2010, 12:14 PM   #3
LILRED66
LILRED66's Avatar
Re: which 235?
Casting numbers, but more specifically, the stamped numbers on the pad adjacent to the rear of the distributor.
The 235 was only available in the light-duty trucks from '60-'62 and will be a J, JB or JC code, but not available in the light-duty trucks from '63-66.
The 230 was only available in the light-duty trucks from '63-'66, but not available in the light-duty trucks from '60-'62.
The 250 was only available in the light-duty trucks in '66, but not available in the light-duty trucks from '60-'65.
The 292 was only available in the light-duty trucks from '63-'66, but not available in the light-duty trucks from '60-'62.
LILRED66 is offline   Reply With Quote
Old 06-07-2010, 06:45 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: which 235?
1963 you could get the 230 as standard equipment in a C50 or a 292 as an option. C60 standard 292, optioned V8.
