control arm cross shaft question
I have a 68 1/2 ton 2wd. I am replacing the upper and lower control arm cross shafts. I bought new ones and got the shafts installed in the control arms. After mounting them on the frame the cross shafts didn't appear to be certered. I pulled them off and spun the shaft on the lowers and got them close. I tried the same on the uppers but they seem to be binding after about 2 turns and are still not cetered. Is there a procedure to install and center these? Should they spin freely? My Haynes manual doesn't say anything and my searches on here haven't given me much. Thanks for your help.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
Re: control arm cross shaft question
I thought the lower shafts have dimples in them that only allow you to install them one way.
The dimples on the lower shaft go into the brackets on the front crossmember were the ubolts are. I centered the shaft best I could and then started turning the nuts in a little at a time on each side until they were tight. Same way for the top
Tim |
Great. I installed the shafts and tightened them down off the truck then i installed them. It sound like that is what i did wrong. I will loosen up the nuts and start over and see how that goes. Thanks for the help guys.
