A/C done the cheap way
My 68 was a factory air truck that had the condenser, compressor and the hoses missing when I bought it. I had added a serpentine belt setup a while ago that had the compressor with it. After a few days in the 90's with the good ol' Florida humidity I figured I needed to do something. I got a evaporator and condenser, and hard lines from a 1987 Camaro. The evap fits in the factory suitcase with a little Great Stuff foam spray around the edges. The condenser was a tight fit but with a little trimming and some homemade brackets it fit in. A late 80's early 90's S-10 donated it's hoses. New o-rings and drier/accumulator, a little wiring, some 134a and there you have it cheap A/C.
Re: A/C done the cheap way
nice work!! i need to do this one day.... Phoenix sucks with no a/c!
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
At least it's a dry heat.
![]() Join Date: May 2005
What kind of vent temp are you getting?? How much 134 did you need??
I want a/c... Texas sucks during the summer
6>8 Plugless........
![]() Join Date: Sep 2007
Very cool info for others doing it on the cheap as well! nice job!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
under the dash or in dash vents? pics pls
#11 | |
'69 Chevy SWB
![]() Join Date: Feb 2009
So is an oven, but I don't wanna be hanging out in there. At least that's what I tell my dad. (He lives outside Phoenix)
Matt ![]() ![]() ![]() ![]() ![]() '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
#13 |
#14 |
That would probably be PAG-100 then. I believe the 3 common ones are PAG-46, PAG-100, and PAG-150.
I've been doing a lot of reading lately to retrofit to 134A in my 87', but I still haven't seen a concrete answer on what viscosity to use. Thanks for the info! |
#15 |
The bottle does say PAG 100. I sure hope that is the right one! I had a friend of mine help me and he is pretty knowledgeable about these things. He hasn't steered me wrong yet.
#16 |
Hey dude just noticed your in pcola. I'm up in pace. What part of town are you in?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#17 | |
Took it to my A/C guy and he said all he had to do was make up 2 Hoses and recharge the compressor. Wirring Harness was there and so was the Vent tubbing. $200.00-$300.00 tops and it'll be done! ![]() P.S. That may be a good idea to hook it up ASAP, as we may be relocating from Northern California, to the Desert Hot Springs/Palm Springs area of SO CAL!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 06-08-2010 at 01:46 AM. |
#18 |
You didn't say exactly where the compressor came from.
New compressors and factory systems that had 134A would most likely had PAG oil. If you are using a used compressor that had R12 in it you should use Ester oil that is on the shelf next to the PAG oils. PAG oil does not mix well with the old R12 compressor oil, according to every source I have read. Ester oil is compatable with the R12 oils. The Ester oil has worked well with the conversions I have done. Just to be on the safe side and knowing it is compatable, I still put 6-8 oz of sacrificial Ester Oil into the pump to flush it out. I shake it and cycle the pump a dozen times while I'm pouring it all out. If you find metal in this oil there is no sense mounting it. |
#19 |
#20 | |
