Old 06-07-2010, 09:08 PM   #1
SS68
SS68's Avatar
picture needed sway bar mount brackets
I am needing a picture of the front sway bar brackets that are welded onto the frame, i had them on my 70 frame but they are not on the 68 frame. If I purchase a front sway bar kit will it come with the mount brackets? not the ones on the control arm but the ones on the actual frame.
SS68 is offline   Reply With Quote
Old 06-07-2010, 10:17 PM   #2
suville
suville's Avatar
Re: picture needed sway bar mount brackets
Those mount are rivited to the frame ECE sells them, I also have several of them if youre interested PM me.
suville is offline   Reply With Quote
Old 06-07-2010, 10:44 PM   #3
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
What would a complete sway bar setup for my '69 C10 cost me shipped to 37806? Thank you
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-07-2010, 10:56 PM   #4
gkesseru
gkesseru's Avatar
From an 81 on my 68
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 06-08-2010, 06:11 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
These were the original brackets tht came with my sway bar (of a leter truck) but they were very beat up and one had been welded so I went with a set of the ECE lowered brackets that tuck the bar up closer to the frame, much neater even on a standard height truck like mine.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-08-2010, 07:31 AM   #6
tasian
tasian's Avatar
heres a great write up on putting a sway bar on more then worth a read
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
