06-08-2010, 06:04 AM | #1 |
WTB 1971 chevy upper coil spring mounting bracket.
I am looking for a set of upper rear coil spring mounting brackets that attach to the rear crossmember under the frame rails.
06-08-2010, 06:42 AM | #2 |
67-72 parts collector,…
Re: WTB 1971 chevy upper coil spring mounting bracket.
ECE (Early Classic Enterprises) sells them new,... if you can't find any used.
06-08-2010, 12:23 PM | #3 |
Thanks for the reference lolife99, but the only thing I can find there is the coil spring retainer cup. What I am looking for is an "L" shaped braket that is riveted to the frame and to the rear crossmember. I believe this is what the reatiner cup bolts through.
