I installed my ECE 4/5 drop kit on Sunday and today I took it in for an alignment and they said it's too low to drive onto the alignment rack.
How did you guys get an alignment after lowering? I didn't think it was THAT low, but apparently it is.
~Zack '71 Chevy C10 LWB '01 Harley Softail |
motor exploder
Re: Too low for the alignment rack
Find another shop! - this is just speculation, but they just may not want to try and align a lowered truck. I've had some slammed static drops on a few different trucks and never had a problem with anyone getting it on an alignment rack.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
I found a local shop who seems like they do this sort of thing pretty regularly. I'd rather go to a locally owned business anyway.
http://www.hooverwheelalignment.com/
they do not want to do it. Find someone else.
I know that a lot of the guys around here won't touch our trucks. Maybe a different place would be more helpfull to you. I would think that a lot of cars are lower than our trucks so I think that they are trying to get you to go somewhere else.
1964 volkswagon, dune buggy 1972 cehvy c 10 with 48000 miles original, bought brand new by my grandfather 1978 chevy elcamino |
i agree ^^^
they could have gotten in on the rack by using boards to get the front up before it hit the rack. they just dont want to mess with it. |
Registered Cruiser
You can't really blame them for not wanting to work on your altered suspension. They could have told you so though. Check with a speed shop in your area. They should be able to recommend someone.
I intend to live forever. So far, so good. |
just bring some good planks with you. That what i did lol
Tot Roddin'
My GM dealer was able to do it without any issues... IMO, look at another shop.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Getting a lowered truck like yours on a rack would be easy with boards. Hell, I can get my '94 Z28 that only has about 3" of ground clearance on a normal alignment rack. They just don't want to do it cause aligning lowered cars is alot more time consuming than a simple "toe-and-go" alignment." There are also specialty shops that have alignment lifts that are built into the ground (had one in my GM ASEP class), so a car with .5" ground clearance could drive right on with no issue.
Crazy
'72 Chevy Longbed 327 w/ 3 on the Floor-soon to be DD '71 GMC Longbed (originally bought project, now parts truck for '72) '94 Camaro Z28 cam/exhaust/gears '02 Chevy Impala-DD for now -Ryan, GM Master Technician |
![]() Join Date: Feb 2003
stack 2x4 boards before the rack..
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
dazed and confused
my truck is lowered 4/6 and the shop that aligned said no problem. great people to do business with. i think you need another shop.
members met: redbaron69, billsbowtie,nc67 |
#13 |
vw guy & now c-10 guy
![]() Join Date: Sep 2008
yep, we just use some long 2x6s to get low stuff on our rack at work. they just didnt wanna mess with it.
#14 |
Definetly find another shop mine sits pretty low up front and it went on my aligment rack without any problems at all.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#15 |
![]() Join Date: Sep 2005
The shop i use had the aligment racks in a pit so the ramps a level with the ground
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#16 |
First shop ( big name brand store ) I took my 69 said altered suspension (i.e. lowered) was more $$$. So I found a mom and pop shop who did it for regular rate.
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
#17 |
Tot Roddin'
I'm telling you... Chevy Dealership ($49.95 or $59.95 can't recall), no boards needed to load it on the rack. Money (safely) well spent IMO.
