My starter is to big any help i need a small one.........
I have a 327 out of a nova in my 1969 c10 4x2 I just put on some block huge-rs headers and now my stock starter is to big Do's any one have a part # that will fit and me as small as can be thanks the truck in question http://67-72chevytrucks.com/vboard/s...d.php?t=361168 |
Truck and auto performance nut
Re: My starter is to big any help i need a small one.........
both summit and jegs sell plenty of different manufacturer's "mini" starters.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
chrome ones start better///powermaster from speedway motors
Is it plug and play or do i need any thing to make it work bolts mounting plates shims ???
thanks |
so is this what i am looking for ??
http://cgi.ebay.com/ebaymotors/Chevy...item19bccf1150 or this one ? http://cgi.ebay.com/ebaymotors/3HP-M...item53e1c9cef6 Last edited by mr mike; 06-08-2010 at 04:44 PM. |
Thats it.I have the same starter in my truck.It even sounds cool starting.And yes plug and play.
big old burb in primer.lot of work to do. |
*** That's interesting ***
Napa also sells them as "Hi Perf" versions if you want a local store (I like doing it that way so I have somewhere to return it to if it breaks). There are other "stock" replacement sources for these "Nippon-Denso" style starters depending on how many teeth your flywheel has.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
the problem on some mim starters you may find is if you still have an original points type dizzy is they dont have the post fpr the 12volt bump to the points on ignition
#9 | |
I called advanced auto parts and the guy had no idea what i was talking about he just keep asking me what year was it lol so i played along for a little bit.. this is how it went....... what year is your truck (69 c-10) what egn (327) no its not (yes it is it) cant be (why not) the computer is telling me 327 is not a op-shin (you asked what year the truck is not the egn) ok what year is the egn (67 ish) what truck did that come out of ( it did not come out of a truck it came out of a car a nova) .... you can do that ( do what ) put a car egn in a truck (lol yes yes you can never mind Ill call napa). that was fun ![]() ![]() |
A lot of guys (including me) run the Skip White mini starter that Skip White sells on Ebay and it works fine for cheap. Includes shims and bolts. Easy to wire up.
#11 | |
Now the others dig........
![]() Join Date: May 2002
![]() Quote:
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
