Old 06-08-2010, 03:19 PM   #1
sixbangr
sixbangr's Avatar
250 balancer/timing?
engine is out of a '76 olds, it is a Chevy 250. The orange balancer appeared to be broken . i just got one from a '75 Chevy, marks seem in the correct place. With the old one , the timing had to be advanced about 2 inches past the timing tab to run so the new one looked correct. It runs best at about 2 inches on the other side of the tab. The gears line up fine and when i put the old one on it matches the timing marks on the tab. Very confussed. How many balancers did these have? The new black one is also thinner and much lighter.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 06-08-2010, 04:06 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 250 balancer/timing?
To answer your question re. how many balancers:
I believe there were a lot of balancers that would fit the crank that there were made for other small block and six cylinder engines.
What you need to do is find TDC on the number one piston and make a mark at "0" on the timing chain tab. I've used a file and/or piece of hack saw blade to scribe the mark.
68gmsee is offline   Reply With Quote
Old 06-08-2010, 05:42 PM   #3
sixbangr
sixbangr's Avatar
well i did find out they changed them from '74 and '75. The newer one I just bought won't work,it is a '74, needed a '75+. Still don't know why my timing is so far off. Truck runs ok, just can't set the timing with the marks, so don't really know what it is set at.
Old 06-08-2010, 07:34 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I just took another look at your timing tab on the timing chain cover. It looks like it's different than what we have on our year trucks. The tab seems to be on the opposite side as mine is on my 250. Am I seeing it correct?
Maybe Oldsmobile covers and pulleys were different. Try to find a cover at a junkyard or buy one from one of our vendors. Chevy dealer may still carry them in some places.
Old 06-08-2010, 08:00 PM   #5
sixbangr
sixbangr's Avatar
that's because GM decided to change it in '75-'76. The one from the '76 250 has 9/16 between the grooves. The early one, like the one they sent, and yours has 1/4" between the groves. Also the marks are on the other side.
