Old 02-15-2003, 01:35 AM   #1
BraveDave
Is there a trick to this?
I am installing 3" rear lowering springs and 2" lowering blocks in my '72 this weekend. I think I can figure it out, but is there some trick that I need to know before I get started? Thanks in advance!
Brave Dave
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Old 02-15-2003, 05:23 AM   #2
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I would have to say get a can of wd-40 and an impact gun. The bolts that hold the spring cups on are hell to get off. I don't know about the blocks. Have you C-notched your frame? I've heard lowering more than 4 inches you need a C-notch. Hope this helps. Oh I would get a few spare bolts for the spring cups b/c I snapped one of mine.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 02-15-2003, 11:57 AM   #3
Gee_Emm
You might want to pre soak all the bolts, the u bolts and the spring bolts and consider the posibilty that you may have to replace some of the bolts, check out the threads when you get them off.
Gee_Emm is offline   Reply With Quote
Old 02-15-2003, 02:32 PM   #4
moose
I did this last week and I use a some liquid wrench and lots of heat I think the heat worked the best and very large breaker bar. then its a b!tch to get the trailing arm lose from the axle I still haven't free the left side up yet. I'm installing 2in lowering blocks on mine hoping to get done tomorrow and or monday. Good lock with yours. Moose
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 02-15-2003, 10:20 PM   #5
BraveDave
DANG!!!!! I gave up. There's no way I could get those things loose. With considerable effort I managed to loosen one lower bolt (barely) but the uppers would have been impossible. I took the truck back up to the Firestone shop. They said they would charge about 2 hours shop time, so no big deal. Some things are better left to the pro's (and I use the term loosely). They didn't do the alignment right when they installed the front springs and spindles, so it would have had to go back to them anyway.
