06-08-2010, 03:42 PM | #1 |
Active Member
Detent Plate 4 speed automatic
Just curious for those of you who have done a 3 speed to 4 speed automatic transmission swap, what did you use or where did you find a 4 speed Automatic Transmission column Detent Plate?
I'm having trouble finding an aftermarket piece or what to use at all for that matter.
"The Great State of Florida" |
06-08-2010, 04:05 PM | #2 |
Re: Detent Plate 4 speed automatic
I just saw a thread on this recently, can't find it now. Maybe this will help some..... http://www.classicchevy.com/product....1&dept_id=1714
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
06-08-2010, 07:49 PM | #3 |
The detents are in the transmission. I just used an aftermarket shift rod linkage with heim joints that goes directly from the column to the transmission and adjusted it so that it hits all gears. The indicator is a little off. For example OD is between N and D. Works fine.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
