'72 C10 Crate Motors
I'm fixing up a '72 C10 Cheyenne for a friend of mine, and he wants to put a fuel injected crate motor coupled to a 700R4 in the truck. In my searches I have only found the GM Performance 350 Ram Jet. Are there any other options for less then $5000? And what kind of modifications will there be to fit the new motor and tranny in the truck? Thanks.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: '72 C10 Crate Motors
You could do a 6.0/4l80e for around that
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Location: Aurora,Il ..born,raised and still live in the same house
if it's "other" than fuel injected...
yearone has a 400+ hp 350 that goes for just under 3 grand! I am currently looking at an "all original" '63 impala and the yearone 350 is definately FIRST thing on my list. |
Truck and auto performance nut
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 06-08-2010 at 07:33 PM. |
He could buy a gm crate engine and then buy an aftermarket fuel injection set up from various suppliers such as Holley, Powerjection, Edelbrock, etc. which come with the controller, etc. and get under 5000.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
True!
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
![]() Join Date: Apr 2009
You Should Check The Year One Crate Engine 400hp and there Built Buy The Same Place That Dose GM Crate Motors... Run Just as good as a GM Crate Motor
Man of Mini-Talents
Might I suggest an LQ4 then? It's the 6.0L truck engine from the 2500's. Basically, an iron block LS2.
You can pick them up cheaper than LS2's, stroke and forge it easier (no worries about cylinder liners), and they'll accept L92/LS3 heads easily. And they're not much heavier than the LS2's. They make very stout, relatively budget friendly motors. |
If you're looking for a good basic setup, here's something for less than $3000
GM 350 longblock 260hp / 350tq 3yr 100,000 mile warranty (pre 85 style) $1500.00http://www.jegs.com/p/GM-Performance...ges/752506//-1 Complete GM style throttle body system $1100.00 http://www.affordable-fuel-injection...&id=5&parent=9 Intake manifold, used TBI, aluminum 4barrel???? $300.00 max |
![]() Join Date: Aug 2001
I'VE PUT TWO OF THE G.M. 230 HORSE CRATE MOTORS IN TWO OF MY TRUCKS. THEY ARE "HECKO IN MEHICO" & THEY ARE DECENT MOTORS. THEY ARE ABOUT $1500. THEY ARE O-K FOR THE MONEY. I'VE BUILT QUITE A FEW 350s & I CAN NOT BUILD ONE THAT CHEAP. I'VE ALWAYS REPLACED THE CAM WITH A SMALL DUAL PATTERN.. SAY ABOUT 468 & 454 LIFT, PERFOMER INTAKE 600 CFM CARB & A GOOD SET OF HEADERS. I DON'T KNOW HOW THEY WOULD BE BOX STOCK, BUT THEY ARE A GOOD 4 BOLT PLATFORM TO START WITH. FOR 1500 YOU GET A 4 BOLT WITH ALL THE MACHINE WORK DONE, ADAQUIT (SP) SET OF HEADS FOR A CRUISER & A THREE YEAR 30000 MILE WARRENTY (I'VE YET TO USE THEIR WARRENTY, BUT IT WOULD BE WORTH SOMETHING TO SOMEBODY THAT IS NOT REAL MECHANICAL). TO SAY YEAR ONE MOTORS ARE MADE BY THE SAME PEOPLE, IS NOT MUCH OF A SELLING POINT TO ME,(I KINDA DOUBT THAT) BUT HEY... ALOT OF PEOPLE BUY THOSE $800 PEP BOYS REBUILT MOTORS & SWEAR BY THEM, OR BUY THOSE $16 HARBOR FREIGHT TORQUE WRENCHES & CLAIM THEY WORK AS GOOD AS MY SNAP-ONs. PERSONALLY I WOULDN'T LET THEIR MECHANICS WORK ON MY WHEELBARROW. TO EACH THERE OWN OPINION THOUGH.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
