06-08-2010, 06:47 PM | #1 |
low n' slo
differences in tierods? (years)
i got a few bucks to mess around with and i might as well replace the tie rods and sleeves since i got the front end apart. i was checking out rockauto because they have by far the cheapest priced parts. but, since im ordering online, i would like to make sure i get the right part the first time. how can you tell the difference in years for the tierods?
my truck is a 67 that had disc brakes on it, so the po had already started upgrading the suspension. im not sure what year they replaced everything with. i bought new 67 spindles (63-70), 73 rotors, bearings, and calipers. i want to make sure i get the right tie rods for what i have. thanks for any help!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-08-2010, 07:12 PM | #2 |
67-72 parts collector,…
Re: differences in tierods? (years)
tie rods from 67-70 are the same, and the rest are grouped 71-72, and 73-87.
06-08-2010, 08:04 PM | #3 |
low n' slo
so could I just get 67-70 tie rods since I have 63-70 spindles?
06-08-2010, 09:36 PM | #4 |
Yes for the outers.
Is the centerlink original? Was your truck a drum brake truck when you got it,... or had it been changed to disc already?
06-08-2010, 09:41 PM | #5 |
low n' slo
not sure. the truck was already switched over to disc brake when i bought it.
06-08-2010, 10:07 PM | #6 |
Can you post a pic of your front suspension?
06-08-2010, 10:13 PM | #7 |
low n' slo
ya, ill snap a pic when i get off of work tomorrow
06-09-2010, 02:41 PM | #8 |
"my truck is a 67 that had disc brakes on it, so the po had already started upgrading the suspension. im not sure what year they replaced everything with. i bought new 67 spindles (63-70), 73 rotors, bearings, and calipers. i want to make sure i get the right tie rods for what i have. thanks for any help! "
67 spindles will be for drum only. these will not support 73 and up rotors. chances are that if the front end already has rotors then the steering rack was swapped as well, When you buy them, Ive noticed some of the suppliers have the same part #s as o reillies (hmm) you might be able to avoid shippingcharges. I swapped to 72 front end and used the tie rods, the outers were I believe the same from 71-87 just go to o reillies and look up 72 tie rod ends and an. . .lets say 78 chevy truck and see if the part #s are the same
1967custom |
06-09-2010, 04:45 PM | #9 |
I agree with the above. The parts combination you described will not bolt up if you use all factory parts. You need to determine what kind of spindles you have before buying any tie rod ends.
Ray |
06-09-2010, 04:50 PM | #10 | |
The problem is he doesn't know what year disc brake parts were installed by the previous owner.
06-09-2010, 04:57 PM | #11 |
Oh, that makes it easier then. The aftermarket conversion spindles I have looked at take stock 63-70 tie rod ends so you can keep your stock center link.
Ray |
06-09-2010, 05:22 PM | #12 | |
That's what I'm trying to find out,... if the steering linkage has been changed. It may have all 73-87 stuff under it.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-09-2010 at 05:22 PM. |
06-09-2010, 05:44 PM | #13 |
take pics of the tie rod ends inner and outer and if you can, measure the thickness. The 71-and up tr ends are alot thicker that 63-70 tr ends in the threaded area. if you have a buddy with a 63-70 look at his, the difference in thickness is obvious
1967custom |
06-09-2010, 06:25 PM | #14 |
low n' slo
heres some pics, i know they are crappy, i took them with my phone
heres the middle centerlink, with years of crud all over it lol tie rod and where the tie rod meets the centerlink
06-09-2010, 10:26 PM | #15 |
The crossmember and everything look original.
I would try to buy '67 tie rod ends. The a-arms are definitely 67-72 style with the steel bushings.
06-09-2010, 10:52 PM | #16 |
low n' slo
the lowers I bought..they are from a 70. the uppers are what came on the truck when I bought it. I guess ill just buy the 67-70 inners and outers and hope they work.
also, for the adjusting sleeve, does it matter if you have manual steering or power? mine has power, but the price for the ones that say for manual is like $6 a piece. the price for the sleeves for power is like $30 piece. big difference!
06-09-2010, 11:24 PM | #17 | |
Ray |
06-10-2010, 06:13 AM | #18 |
low n' slo
ah ok..good info. I'm pretty sure its not stock ps...thanks
06-10-2010, 06:30 PM | #19 |
it looks like the whole front crossmember has been swapped, notice the tab for the brake line is in the front of the crossmember, 63-70 have that tab in the back. it looks like you have a 71 72 set up there with 67-70 tie rod ends hooked up , that might be why that boot is torn. It might not be correct for the hub thats on there now. (not seating correctly)
1967custom |
