The 69
I bought a 1969 short bed a few years back and now i should have some time and money to finally work on it. I plan on doing the suspinsion and drivetrain this winter and go from there. Right now it has a 454 with a 700r4 and I want to get rid of it and go with the newer 5.3 or something along those lines. Ive already got most of my Suspinsion stuff from porterbuilt both front and rear now I just need to install it..
Still Learning
Re: The 69
Wow! did you buy the truck in that condition? Looks like a great start
![]() Glad to see another Okie build too! |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: The 69
We need some more pics.... Nice ride to start with for sure..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: The 69
Here are some more pics of the truck. I put the centerline wheels on it and lowerd it with a No limit fual cell I put in about 3 years back .
Re: The 69
Room full of goodness
![]() Join Date: Apr 2005
Re: The 69
Great start! Boomer Sooner!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: The 69
Still Learning
Re: The 69
Looks like a pile of parts!
Re: The 69
Re: The 69
You have all those parts and you haven't started yet ? What are you waiting for ?? J/K looks good!
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 |
![]() Join Date: Sep 2007
Re: The 69
more pics!
Still Learning
Re: The 69
#13 |
Re: The 69
#14 |
Re: The 69
Once summer is over ? I'd knock out the suspension now, keep the big block in it and rock it for the rest of the summer. Then do the LS motor in the winter. I find that when you make your projects a series of small projects instead of one big one they seem a little more obtainable but that just my .02
#15 | |
Re: The 69
#16 |
Re: The 69
I'm just giving you a hard time. Don't change your mind based on my opinion alone. Do what you want to do. To do power steering you will need a power rack, line kit for the rack with rack fittings, and a pump, resivore, pulleys and brackets for a big block depending on which water pump you have, short or long. It may require some research to find which combination you need. You could go stock or aftermarket depending on what you want to get into or what you want to spend. I got lucky my truck already had power steering on it so I have everything I need when I switch it back over.
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 Last edited by 5windowpickup; 06-14-2010 at 09:11 PM. |
#17 |
VA72C10
![]() Join Date: Mar 2008
Re: The 69
looks and sounds like a cool project!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#18 |
Still Learning
Re: The 69
Couldn't just change it to power steering gear box and add a pump? I know that sounds easier than done, but there should be some parts around to get it done.
#19 |
Tot Roddin'
Re: The 69
Great looking project; can't wait to see it come together!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#20 |
Re: The 69
Getting rid of the big block has been a back and forth battle for me. Im ready to get the truck back on the road, but while its down I would like to make it easier to drive. Its hard to pass up the 5.3's.. They have low mileage motor and trans for 1800 bucks in the salvage yards..
#21 |
Re: The 69
Im thinking about saleing the 454 and 700r4. The motor runs great with a small cam,new holley double pumper 850 and new hei stuff from msd. The 700r4 lost 3rd and 4th. Im wanting to sale it complete from carb to oil pan. I just droped 800 bucks in the carb and hei stuff. The carb has 5 miles on it maybe 50 on the hei stuff. Whats a good price for something like this?
#22 |
Still Learning
Re: The 69
It sucks you dropped all that cash in the new parts, you know your lucky if you get half of what you gave for them. With that said, I'm not sure what these are going for? good luck with the sale.
#23 | |
Re: The 69
#24 |
Re: The 69
#25 |
Burnouts are therapeutic
Re: The 69
great looking project, if your going to sell the big block deffinently leave it in the truck and post it for sell, most people won't even consider buying an engine they can't hear run. If it runs well and doesn't smoke or use oil it would bring $1500 to $2000 around here.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
