Road trip essentials
What do you guys bring in your truck on a road trip? I have pretty much the whole garage in my truck's bed right now (fluids, spares, tools), but y'all might remind me of something I forgot. I've checked every fluid, nut, connection, tire pressure etc. and she's running like a top. Pray for me
'72 cheyenne super step, '05 long bed gmc |
![]() Join Date: Nov 2003
Re: Road trip essentials
A cell phone and a list of phone numbers of contacts along the way.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
My Dad road trip tools consisted of the following: a mag light, duct tape, a flat head screwdriver, a gallon of water and a crescent wrench.
1969 C10 stepside 1973 Cheyenne Blazer |
got er covered so far. Three gallons of 50/50 and two rolls of duct tape
Gone to greener pastures
![]() Join Date: May 2007
Where to start?
A fairly complete tool box, extra fluids, flashlight (preferably 3 or more batteries) with new batteries in it & a spare bulb, reflective safety vest for roadside repairs, coveralls so the inside of the truck don't get grubby after roadside repairs, hand cleaner or handi-wipe type towels, "Rescue Tape" if you can find it, duct tape, cell phone, truck board emergency contact list, lots of drinking water or Gatorade, energy bars; if you're going someplace really cold, a survival blanket. That's all I can think of off the top of my head. When I remember more, I'll add it. Some people think I overdo it, but when I'm on the road I'm driving a truck that's 40+ years old & sometimes the unexpected happens, or something breaks.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Yep, I have a chase vehicle the whole way thankfully. Mom is following me halfway and my grandpa is leading the way from there.. Only way she would let me drive this truck six hours away
hah, you should see what all I got in the bed of this thing.. I have the stuff tied up in grocery bags, filled up enough to where nothing can go flying
#8 | |
But if you're going to fly to pick up a vehicle & then drive it cross country to home, don't put a lot of stickers on the ice chest.
yep, biohazard stickers don't fly (heh) with airport security. I remember reading that epic
Between Trucks...
If you don't have a spare, I'd at least have some cans of fix a flat.
Beat it to fit, Paint it to match... ![]() |
In addition to already mentioned, AAA membership, 12v inflator, liquid wrench, extra plug wires/plugs, rocker arm/nut, rad stop leak, 18" of fuel hose, extra belts, chewing gum and bailing wire.
![]() Join Date: Aug 2001
I ALWAYS KEEP MY JUNKYARD TOOL BAG BEHIND THE SEAT. A CELL PHONE IS A GREAT IDEA TOO. (ALTHOUGH I DON'T OWN ONE) I'VE FLOWN 800 OR 1000 MILES SEVERAL TIMES TO PICK UP AN OLD TRUCK & DRIVEN IT HOME. KINDA EXCITING, & I'VE NEVER HAD TO WALK YET. (KNOCKS ON WOOD)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#13 |
Between Trucks...
Regarding the fix a flat. Just walked out to a flat tire. The can of fix a flat didn't inflate it. I guess they're not all created equally. Did have a flat tire repair kit which did work. So maybe a 12 volt air compressor isn't such a bad idea instead.
#14 |
The best advice I can give is do a through safety inspection on it before you hit the road. Hopefully you can catch something and fix it so it won't leave you on the road.
Pay special attention to; brake and fuel hoses (cracks, swelling) and steel lines (rust, leaks) leaks around wheel cylinders / master cylinder radiator hoses (cracks, swelling) loose bolts / lug nuts tires (cracks, nails, plenty of tread) lights wiper blades wheel bearings universal joints (lube and check for looseness) wires (broken insulation, not contacting sharp edges, exhaust) check all fluid levels including rear end tie rods / ball joints / steering (check for excess play, loose nuts and lube) alternator (noise and charging voltage) belts (glasing and cracks) brake pads / shoes and drums (cracks, thickness) I'm sure I'm forgetting something, and don't forget extra fuses, bulbs, lug wrench and jack and spare set of points or ignition module. |
#15 |
Happy to be here
![]() Join Date: Mar 2000
Cell phone and Amex along with a pocket full of Bens and I roll....
#16 |
![]() Join Date: Jun 2002
sunflower seeds
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
#17 |
the hope for good weather and a big freaking hammer are the only things that i can add on!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
#18 |
she ran great guys
#19 |
also, 204 miles and I only burned 3/4 of a tank of fuel. With crazy wind, 70+ mph the whole way. 90+ mph five minute sprint to catch my mom when a lady cut me off then stopped at a yellow..
#20 |
Prestige Worldwide
![]() Join Date: Feb 2001
#21 |
Thats what I was thinking...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#22 | |
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#23 | |
What they said!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#24 |
blood type; Retumbo
light weights!!!!
bag of Twizzlers, pack of Camels, Thermos and mug, and a buddy to pay for gas when you drag his 67 1 Ton dump bed back from 400 miles away. LOL when's our next trip Shawn? |
#25 |
getting a 2 liter coke, ice chest to keep it cold, and peanuts to put in it for the return trip.. Now that I know it'll go anywhere i'm going to get one of my friends to pay for gas to go to an awesome junkyard about two hours away.. He ran his mustang into an overpass concrete pillar lol
