![]() Join Date: Dec 2009
Drive Shaft length
Well I am still working on the front end rebuild on my 71 SWB truck frame.
I am about ready to instal the engine and transmission. So, I got to looking at the rest of the driveline. I notice that the drive shaft SHOULD be a real short shaft from the trans to the carrier bearing location, due to the location of the trailing arm mounts and the trans crossmember, as compared to my LWB. My question is: the length of the drive shaft for a SWB from the top of the training arms (or where the carrier bearing would be), down to the diff, is the same as the length for shaft for the LWB? So theoretically, I could swap out the shaft from the Carier Bearing to Diff from the other truck, and just get a short shaft from the trans to the CB?
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. |
Re: Drive Shaft length
Well after looking at the underneath side of a SWB I noticed there in NOT a carrier bearing.
The drive shaft goes straight from the tranny to the diff. So, is the shaft the same lenght as the LWB or is it entirely different?
if wanting to find good driveshaft length to work right the first time// measure it
#4 | |
Entirely different. Someone has changed your 2 piece shaft out for a 1 piece shaft. Works well on SW trucks.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
