Wheels on 1.25 rotors
Okay, I did a search for this and the more I read the more confused I got.
I have a 1991 'Burb frontend under my '67 build which gives me the 1.25 rotor and I have a 4/6 static drop. I am considering 18" wheels and have even found some great prices but it looks like major fab work to get most wheels to fit up front. A little nip and tuck I get. Blowtorches, welders and the jaws of life are a little more than I want to take on. I know that some of you fellas are running 18"s on 1.25 rotors, I would just like for you to let me know what you got. Thanks
Rex |
Re: Wheels on 1.25 rotors
i had coys 18x8 with 4 in BS on my 90 burb and had no problems, just make sure and run a short valve stem because they are close to the caliper...that is the only problem i had
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
Thanks for the reply.
Those Coys look real sharp on you ride. ![]()
Rex |
thank you!
