rear set up
if i am running leafs in the rear with bags, how many leafs do i need to take out?
#2 | |
Re: rear set up
That's a loaded question. The leaf spring is doing more than just holding the truck up. (which is all that the air bag can do) The leaf spring is also "locating" the axle and combating "spring wrap" (axle wind up). Removing too many leaves make is too soft and reduces it's ability to do these things. If you go this route, you need to add some kind of traction aide. (Ladder bars, Cal Tracs. ect)
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#3 | |
Re: rear set up
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-10-2010 at 02:13 AM. |
