tranny lines
i got 1978 c10 stepside.that im putting in a th350 auto tranny,i originaly had a 3speed manual but it gave out.my question is how long are the tranny lines that go from the tranny to the radiator?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: tranny lines
i have no clue but ive made them with the pieces you get at the auto parts store and some unions
78 Big10 454
![]() Join Date: Jul 2008
Re: tranny lines
Try this vendor:
http://www.classictube.com/ I got replacement tranny lines from them - perfect fit. I opted to replace rather than repair the damaged lines. |
Old Heap Driver
Re: tranny lines
I usually make mine with sections of steel brake line available at most auto parts stores. Short sections of rubber hose can be used on the ends to complete the connections.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
78K & 79C Jimmys
Re: tranny lines
about six feet i think,using rubber would be the weakest link,i buy a roll and make my own with double flaired fittings,but you should be able to get them that long with the fittings on it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: tranny lines
6 feet with the bends around the frame?. yeah i found them at a local autoparts.my other question is,do i have to get an oil cooler? or just hooking them up to the radiator is fine?
Re: tranny lines
Couple things:
1) Since the truck was originally stick, the radiator might not have provisions for a transmission cooler. 2) You might want to just get the lines off of a junk yard truck and clean them up, save you a lot of time and you know they will work. They also sell them new. 3) External cooler isn't needed but not a bad idea if you plan on using your truck as a truck. In my opinion its cheap insurance and getting the biggest one you can fit is a good idea |
thanx for all the help fellas.i found a place where to get them and they will bend them too. ill let u guys know how it went.once again thanx.
Re: tranny lines
I used 3/8" NPT barb fittings in my th400 and ran rubber fuel hose up to the radiator and ive never had an issue. and that way you can run them inside the frame where you want. steel line are a PITA in my opinion.
USMC Former SGT 2002-2006 Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks. The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891 2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612 |
| Bookmarks |
