How-To on charging new A/C system
I am about to install a CAA A/C system in my '69 this weekend. I have never owned a vehicle with A/C or messed with A/C before.
I have searched on the site for a How-To on charging a new system and I have googled it, but I didnt turn up anything that I thought gave good instructions. Does anyone know of a good website or post on how to charge a new A/C system? I have borrowed a vacuum pump and I have my dad's old A/C tool box that has gauges and various tools he used when working on A/C and refrigeration systems. I could go pay someone to do it, but I feel that defeats the purpose of the learning that comes from doing it myself. |
Re: How-To on charging new A/C system
i am in the heating and a/c biz. it would be worth the money to have someone do it. there are several variables to charging an a/c system properly. first is a good vacum with a micron gauge and pull it down into a good vacum according to manufatures specs, you will also need the proper gauges for the refrigerant you are using and you will need to weigh in the charge, once again according to manufactures specs. if you want your a/c to last and run properly a good a/c tech will be your best bet in my opinion. just my 2 cents, so good luck in whatever direction you decide.
#3 | |
![]() Last edited by mbgmike; 06-09-2010 at 08:04 PM. |
'70 C-10 Primer
Besides, it's dangerous. Accidently breathing in freon can kill you.
"The difference between stupidity and genius is that genius has its limits." Albert Einstein |
ACForum.com
![]() Join Date: Feb 2001
Sometimes when we try to save a dime we end up spending a dollar. What I am saying there are times when it's best to let someone else do the work for you. Thats just me as I am mechanically challenged. Best of luck. If you do it keep us updated.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Active Member
![]() Join Date: Jul 2007
Thanks for the info guys.
I got it evacuated and charged. Easy enough. Held 29"Hg of vacuum for over an hour. Blowing 33-34 degree air in a 88 deg shop and idle. High side pressure was around 170-175 psi.
Thanks for the website 67vetteal, that answered most of my questions. Also thanks for the extra vote of confidence to everyone else. Last edited by dznucks; 06-14-2010 at 07:38 AM. |
good job, its good that you took the time to do it properly. now come do mine, im from ga. but now live in wa, and i miss the accent!
#11 | |
Your UncleBen
![]() Join Date: Dec 2002
Glad you did it yourself! At least you had the right tools! lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
Moderator
![]() Join Date: May 2007
Congrats on doing it yourself!
After paying almost $1000 one time to get my A/C fixed, I learned how to do it REAL quick.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#13 | |
