Old 06-09-2010, 11:11 PM   #1
solo_0569
solo_0569's Avatar
454 in a 67
has anyone put 454 in a 67 with headers and mt ? if what type of mods do i need to do?
solo_0569 is offline   Reply With Quote
Old 06-09-2010, 11:48 PM   #2
MONTE
MONTE's Avatar
Re: 454 in a 67
I went with Solid motor mounts on my 68 and Hooker header Super Comps.
MONTE is offline   Reply With Quote
Old 06-10-2010, 12:49 AM   #3
mike67
Re: 454 in a 67
Check out this link. These guys used 72 BB motor mounts in their 67 Panel.
http://www.classicheartbeat.com/panel_8.htm
Additionally I just bought a 1967 Stepside Shortbox with a 454 in it. The mounts in my truck look different than the ones above and as you can see from the picture the PO did not select the right headers and used a hammer to solve the problem.
At some point in the future I'd like to redo this setup so hopefully someone else can advise on which mounts / headers would be the best.
Not the full answer you were probably looking for but hope this helps a bit.
mike67 is offline   Reply With Quote
Old 06-10-2010, 12:56 AM   #4
mike67
Re: 454 in a 67
I also found this picture. Not sure what type of headers these are but very nice clearance around the mount.
Old 06-10-2010, 09:44 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
Re: 454 in a 67
That's a small block.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-10-2010, 04:03 PM   #6
raycow
Re: 454 in a 67
The frame bracket in the header pic looks like it might be for a SB?
Ray
raycow is offline   Reply With Quote
Old 06-10-2010, 04:34 PM   #7
solo_0569
solo_0569's Avatar
Re: 454 in a 67
got motor in on stock mounts but need to know about headers and will they work with the z bar for the clutch. Are do i have swap to an auto tranny.
Old 06-10-2010, 04:38 PM   #8
-dylan-(OO==|==OO)
I dont drive fast,, I fly low!
-dylan-(OO==|==OO)'s Avatar
Re: 454 in a 67
its a bolt in swap.... u will just have to get the truck headers.... other than that it should be a bolt in swap .... good luck
____________
/_______\
(OO==||==OO)
67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima
-dylan-(OO==|==OO) is offline   Reply With Quote
Old 06-10-2010, 04:53 PM   #9
MONTE
MONTE's Avatar
Re: 454 in a 67
Hooker Headers
