Old 06-10-2010, 10:29 AM   #1
D-Rat
D-Rat's Avatar
Leaking Transmission fluid
It's leaking around the vacuum modulator. Probably needs a new O-ring. anyone know the specs on that (size/thickness)?
ETA: It's a TH350 trans
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 06-10-2010, 07:56 PM   #2
mclairmo
Re: Leaking Transmission fluid
If you take the old one to Napa or Kragen they can match it up. They have every size. Also, new modulators come with a new o-ring and tube for liek $10-$15. If the o-ring is shot, the valve itself may be very old, too. Also, check that it's not leaking from the valve itself. Also, check that the bolt that holds the clamp on the valve is not loose.
mclairmo is offline   Reply With Quote
Old 06-10-2010, 08:09 PM   #3
D-Rat
D-Rat's Avatar
This is a brand new modulator I got from Napa, but it didn't come with an O ring, the buggers. So I reused the O ring from the old one (that wasn't leaking, mind you), and now I have a puddle of trans fluid in my driveway.
Maybe the truck is just irked that it's so hot this week.
Old 06-11-2010, 04:15 AM   #4
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Believe it or not, when i changed my vacuum modulator i got different shift points.
better shift points (3rd comes quicker)
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
