Have you ever seen a trailing arm modified like this?
I started taking the rear suspension apart to change the trailing arm bushings and I found that the drivers side arm had been modified. I don't see any damage to the arm so I don't think its a repair. Do you think I should replace it just in case?
#2 | |
Re: Have you ever seen a trailing arm modified like this?
looks like a 3/4 ton TA
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
You might want to put a string on it from several differant angles and compare it to the other one, for straightness / lenght from end to end...just a thought.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Senior Enthusiast
CPP actually makes a plate set for doing this down the entire length of the arms for reinforcement. I certainly wouldn't get rid of it because of the plate.
http://www.classicperform.com/Store/...k/6072TARK.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
it may have started to split apart and a po had it plated to fix a soon to be prob
66 chevy lwb 355/400 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I agree.....My '66 C20 has trailing arms that are like that, and I've seen a few other C20's like that as well.
I have seen a number of them, mostly on C20 Custom Camper trucks, so it may have been a dealer-installed option, for the heavier load-carrying capacity for the cabover campers.
here's mine. it's a c20
my c20's got 'em too.
'66 c10ish straight 292 power! |
Yah, but JGross's arm looks like it is spot welded instead of riveted.
Ray |
#11 | ||
I believe the plates that you guys have riveted to the trailing arms are a factory design modification. I speculate that GM had problems with these trailing arms spliting so this was the fix.
I base that upon my own experience with my trailing arms and also based on the following link and the picture below from the 67-72 forum: http://67-72chevytrucks.com/vboard/s...light=trailing Pictures below are GM built arms and they have welded plates. Per a post on the thread I reference above: Quote:
Rottenwood Garage Member
The trailing arms in the 60's had a bad habbit of cracking or splitting and this was a VERY common repair. The one I have was called back to the dealer and welded (plated or boxed)there...according to original owner.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#13 |
Thanks for the input, I think I will go ahead and add some support plates to the other arm.
