Old 06-10-2010, 08:49 PM   #1
astrochimp
gas gauge at e when half full
I got a new sending unit, it works great, but shows empty when still 1/2 full.
At E it will only need 10 gal to fill. The tank should hold 19 gal? On my 63, stock tank.
Ideas? Not sure if I can bend the arm on the sending unit? Or just live with it till I go under bed tank.
David
o- got the wheels and new tires on a couple of weeks ago, MUCH better, will post photos soon. Ralleys painted black, and 255/70R-15 Continental CrossContact tires. I need trim rings and a chance to add the 'special' paint
astrochimp is offline   Reply With Quote
Old 06-10-2010, 08:55 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: gas gauge at e when half full
Sounds like you have a 30 ohm sender in the tank and a 90 ohm gauge, or a bad ground at the dash.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-10-2010, 08:58 PM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Agreed!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 06-10-2010, 09:05 PM   #4
hossmann
hossmann's Avatar
im going to guess that it is a stock relacement (0 to 30 ohm) if thats the case then i would take it out and see how far the float is above the pickup tube it shouldn't be more than 2in i think check this and if you are planing to put a tank under the bed soon id just leave it hope this helps a little
66 chevy lwb 355/400
hossmann is offline   Reply With Quote
Old 06-11-2010, 08:39 AM   #5
astrochimp
Yes stock replacement so both are 30 ohm.
The float rod bent wrong is what I was guessing- I will try to pull it and see how it is vs pickup. PITA so I don't want to do it much.
Old 06-12-2010, 10:37 AM   #6
LILRED66
LILRED66's Avatar
Bending the rod, although a possible solution, is not the proper way to address the issue. I venture to guess it is a compatibility issue with the ohm rating of the gauge and the sender. Do a resistance test on both, to determine if they are the same ohm rating.
LILRED66 is offline   Reply With Quote
gas gauge
