Old 06-10-2010, 10:45 PM   #1
NF65Fleetside
NF65Fleetside's Avatar
Braking issues
hey guys, I fooled around and let the brake fluid get super low and when braking the truck would dive/pull hard to the right....now that I added fluid it is diving/pulling hard to the left....did i get an air bubble in the line?...oh and its def coming from the front brakes. Anyone have this issue before?
NF65Fleetside is offline   Reply With Quote
Old 06-11-2010, 01:03 AM   #2
Captainfab
60-66 Nut
Re: Braking issues
Yeah, it sounds like you need to bleed your brakes.
Old 06-12-2010, 05:23 PM   #3
grs
Re: Braking issues
If the fluid got low you have a leak. If it was me I would go thru the brake system.
grs is offline   Reply With Quote
Old 06-12-2010, 08:58 PM   #4
mikie 1954
Re: Braking issues
could be your brake pad lining could be worn thin and needing repaced. low fluid is a good indicator of this, but nomatter what you need to look at your brakes for leeks,brake shoes, or bad lines.
mikie 1954 is offline   Reply With Quote
Old 06-12-2010, 09:16 PM   #5
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: Braking issues
Yep, time for a bleeding. Also while you are doing that take a look at all of your brakes, there is a reason the fluid is low. Either you've got a leak somewhere, or your pads/shoes are worn. Either way the issue should be addressed for safety's sake.
fryer1979 is offline   Reply With Quote
