Old 06-11-2010, 01:13 AM   #1
tim21391
tim21391's Avatar
new problem..keeps dying
so at around 45 or so truck keeps dying.. at around 45 mph.. then i put to neutral and start and it wont start.. but as soon as i pull off and then start it.. it will fire right up.. whats goin on.. i am still having the problem where its cutting out at 55 and wont let me go past it.. my friends grandpa said i might need a vented distributor cap? i never heard such a thing?? its an accel distributor with a msd cap and rotor..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-11-2010, 01:16 AM   #2
mstrav1973
mstrav1973's Avatar
Re: new problem..keeps dying
vapor lock, fuel pump, fuel filter?
battery and alt good?
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-11-2010, 01:19 AM   #3
tim21391
tim21391's Avatar
ya battery is good had alt tested few months ago its good.. new fuel pump like 3 weeks ago.. all filters are good. how do i check vapor lock? i know its gotta be fuel related..
Old 06-11-2010, 03:45 AM   #4
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
I had the exact same problem ,happened to me when it reached 3rd gear.Would start to die out, then i'd pull over and start it up again. Reach 3rd,same problem
It ended up being the pink -(do not cut) wire from the ignition to the starter was burning out (getting thinner)
so i ran a 12 ga. in-line fuse wire from ign. unfused in the fuse panel directly to the distributor (bat.)and problem solved (for me). I was gettng plenty of gas and spark, but it seemed that when the truck called for more power, it would die.
Don't ask me why or how. An old hot rodder/farmer suggested it and it worked.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 06-11-2010, 03:47 AM   #5
beebster
beebster's Avatar
seems like the old guys/grandpa's are familiar with this problem. LOL
I love stock!
Old 06-11-2010, 03:34 PM   #6
tim21391
tim21391's Avatar
ill have to check that wire..
Old 06-11-2010, 03:38 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Carb, float, jetting problem = to lean or to much fuel (flooding). My 2 cent...
D.PASSMORE is offline   Reply With Quote
Old 06-12-2010, 05:57 PM   #8
tim21391
tim21391's Avatar
wire was good..check floats when i get around to it..
