06-11-2010, 01:15 PM | #1 |
Yet another front Crossmember Question
I'm gonna do the front suspension swap crossmember and all. I've seen several good candidates at local wrecking yards, now rather than spending half a day trying to remove it I wanna cut the frame but they won't allow torches or gas powered tools was thinking a batt operated sawzall but those dont seem strong enough to cut the frame any suggestions?
06-11-2010, 01:30 PM | #2 |
Senior Enthusiast
Re: Yet another front Crossmember Question
You might want to try a different yard if there are any others to choose from. When I bought the 1975 front suspension for my 1960, somebody from the yard pulled around in a boom truck, chained up the crossmember and sliced it off with a torch in about 5 minutes or less. Drove the truck out front and lowered the clip into my pickup for $75. It sure made it easier to move around being in one piece with wheels on it.
I suppose it can be done, but I can't imagine removing the crossmember in the yard by hand. Besides, if you can get the frame rails foward of the firewall with the suspension attached, the frame will provide a template on where to drill the holes for the later design idler arm and brake hoses, along with all the bolts and which holes they go in. And it may also come with a sway bar. As for cutting the frame yourself, even if you can bring something strong enough to do the job, it could be scary dangerous without enough equipment to manage each half of the truck when the last cut is made.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-11-2010, 01:34 PM | #3 |
Under Construction
they wont allow torches in many yards around here. the easiest way to do it would be to jack up the front of the truck, then use jy tires/rims to block up the frame, then start cutting, the 18v dewalts etc, are plenty powerful to cut the frame .
best of luck.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-11-2010, 01:40 PM | #4 |
Thanks for the pic Mark thats what i want to do guess I'll have to find a good cordless I've checked rental yards they dont rent them maybe have to buy one, damm the good ones are expensive.
06-11-2010, 01:45 PM | #5 |
If you want to come get a front end up here in the SF Bay Area, I have an 18 volt sawzall and 7 bat, let me know, I go to the yards all the time too
06-11-2010, 01:49 PM | #6 |
Under Construction
if you have a couple of new hacksaw blades, you could cut the frame manually as well with a hacksaw.... you could get your front end , and a work out at the same time. ask the yard they may have a cordless tool available, run the scenario by them and see how they respond...
06-11-2010, 05:21 PM | #7 |
Let me know if you see any 71-72 coil spring rear ends.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-11-2010, 05:44 PM | #8 |
I cut one off with a sawzall two weeks ago at the junk yard and it only took a couple of minutes per cut. Make sure you bring enough batteries and some new blades.
06-11-2010, 07:14 PM | #9 |
06-11-2010, 07:17 PM | #10 |
06-11-2010, 08:11 PM | #11 |
Remember not to let the blade go full speed. Cut slowly and the blade will last alot longer. When you create heat the blade goes dull. You could do it with a hacksaw also but your arm would surely be tired after...
06-11-2010, 08:19 PM | #12 |
Under Construction
I buy the 10 pack bimetal sawzall blades at homedepot, and jeep them in the case
06-11-2010, 10:22 PM | #13 |
Jesse
I have cut a few frames with the Milwaukee Ice Edge Torch blades and they have worked great. They stay cooler and last longer, but cost more. Try the 9" in a 5-pack.
06-12-2010, 11:49 AM | #14 |
Resistance is Futile
....a can of WD40 or similar will help out, too. Have fun.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-13-2010, 12:16 AM | #15 |
Get some Lenox bimetal blades, they will last longer than any other blades out there. I bet you dont use more than one to cut both sides. my .02
06-13-2010, 02:09 AM | #16 |
x2 on the Lenox blades. I never had one dull out on me before I broke it for some stupid reason haha
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
06-13-2010, 02:46 AM | #17 |
Just saw one on CL, here some place in placerviile, aready cut off and cleaned up, I`ll have to look around.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
06-13-2010, 06:04 AM | #18 |
06-13-2010, 09:52 AM | #19 |
Ya I had PM`d that to him....
01-16-2011, 12:35 AM | #20 |
But Found Her 25yrs Later!
There was a article I read sometime back about wiring your dewalt cordless to a 12v car battery.
It doesn't run at 18 volts and then progressively drain to 8v, then 4v, then dead, but rather at 12v for a long time.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
