what is this??
what is this?? it came off the tranny.. i looked and came up with a tcs solenoid but autozone and two tranny places couldnt tell me what is it..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: what is this??
could this be my stalling problem? why it wont go over certain speed?
Re: what is this??
anybody?
Hollister Road Co.
Re: what is this??
Yes its a tcs solenoid, Its an emmsions part to retard the spark till your in high gear and it should no affect the operation only the emmisions of the engine. The trans reaches a certain pressure it closes a switch on the trans that sens juice to that solenoid and opens the Dist to vacuum andadvances the spark.
More detail on the stalling and speed thing may be helpful. |
Re: what is this??
before i had carb rebuilt it would stall at 70 where it seemed liked someone installed a governor on and it wouldnt go over 70 then after it was rebuilt it stalled at 55 then now its down to 40 and then dieing on me when u gas it.. so i dont know what the deal is... i thought it was this since it wasnt hooked up...
Grandpa in the rustmobile...
Re: what is this??
hook it up lol hope its fixed you have more trouble with that cuttin off
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: what is this??
I am not sure the TCS relay would cause this. Most of us have had the TCS system disabled or removed on our trucks, without any issues.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Re: what is this??
ya it had a wire that was broken off and wasnt connected to anything the vacuum not connected to anything so i just took it off.. and it ran fine at idle.. but who knows this turd keeps getting worse and worse
72 GMC
Re: what is this??
i thought that "turd" was your grandfather's truck !!!
Hollister Road Co.
Re: what is this??
Sounds like a fuel pump or clogged filter. or possible junk in the tank
Re: what is this??
its all about the +6 inches
Re: what is this??
X3
#13 |
425hp409
![]() Join Date: Oct 2008
Re: what is this??
X4
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
#14 |
Re: what is this??
its gotta be junk in the tank then since filters and pump are brand spankin new... and no it was my dads and he gave it to me 3 years ago
#15 | |
Hollister Road Co.
Re: what is this??
I had a issue with my fuel pump. It was bad and I changed it but put the filter in the usual place after the pump. Well the trash in the tank wiped out the new pump, sand stuck in the rubber valves, So I put a filter before the pump, cleaned out the tank and all has been good so far. So I would test it to see if it builds up pressure and holds pressure Last edited by dwcsr; 06-14-2010 at 01:23 AM. |
#16 | |
*** That's interesting ***
Re: what is this??
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#17 |
Re: what is this??
Are you upgraded to a HEI distributor? If not you may want to do so..Points are fine..but if you put alot of miles on it..I would upgrade..My 4 trucks are..They never let me down..
#18 |
Re: what is this??
i have accel hei already
#19 |
Re: what is this??
the tcs will have no effect on an hei that isn't hooked up to it anyway
'72 cheyenne super step, '05 long bed gmc |
#20 |
Re: what is this??
ok
