CST Flooring
Carpet and vinyl flooring lists different part #'s for CST vs. non-CST models. Will the non-cst version fit a cst model? I assume it has something to do with the rear interior panels.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
Re: CST Flooring
I'm going to assume the difference is that the non-cst carpet/mat covers the cargo area from bedside to bedside while the cst part numbers cover from lower side panel mounting bracket to lower side panel mounting bracket. I am also thinking I can use the non-cst part number and just cut it where the lower side panel mounting backets are.
Re: CST Flooring
I belive your assumption is correct. Only problem cutting the non cst down to fit would be your cutting the edging off, don't know what you call it, but it's purpose is to keep the carpet from fraying at the edge.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Re: CST Flooring
Thanks. I'm looking at some vinyl flooring and hopefully it won't be a problem like carpet would be.
