Old 06-11-2010, 10:05 PM   #1
hammerdog57
hammerdog57's Avatar
Camaro clip install tips
Looking for some tips on squaring and leveling a camaro clip in a 57 3100. Truck frame is already set level. Here is my plan tell me if i am on the right track. Going to set a laser chalkline on outside of both frame rails running parallel front to back and center clip shock holes between lines. Also measuring foreward from reference point to front edge of shock holes to establish axle centerline. I am going to set angle finder on upper A arm mounts at 8 degrees to set anti dive angle. I am also going to level upper A arm mounting points side to side. Any thoughts? Using the no limit video as a reference but when it came to squaring the clip to frame video didnt show much detail.
hammerdog57 is offline   Reply With Quote
