Jesse
I just lost 100lbs on the Porterbuilt diet
Well something like that. I'm sure the new Dropmember with tube arms will weigh a lot less. Hey Nate have you ever put them both on a scale to compare? Old vs. New.
Re: I just lost 100lbs on the Porterbuilt diet
Cool man...I have wanted to see some detailed Pictures of one of these installs...
I'm going to have to follow along and check out all your progress. Keep post pictures...I want one of these drop members
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
watching closely.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
me too!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
me too but for the love of jeebus put some shoes on yeah your hand are clean but i think your toes are just as important...imho
#6 | |
Jesse
I'm glad you think my toes are important, I'll be careful ![]() Thanks |
Registered Loser
Maybe you can find some steel-toed sandals.
![]() The aftermarket crossmembers are the coolest idea. I have one on my 63 GMC that I'm building and it sits the pinch welds about 1/8" off the ground.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
Jesse
If i run a 27" WW on a steel smoothie will i be on the pinch weld or is the frame an 1/8th lower
Jesse
Well here is a comparison picture of fat greasy & old and skinny clean & new
Nice! What a great set up. Nate does some fine work and I'll be happy to write the check once I have the $ to back it up. What rack and pinion are you going to use with the drop member?
Jesse
I think the one from Summit, I have herd good things on them.
And there on sale http://www.summitracing.com/parts/SUM-770601/?rtype=10 |
That's a lot cheaper than I thought it would be. Keep us posted on the install and ofcourse, we need some pics. Thanks
#13 |
How do the Uppers Connect? And who makes this crossmember setup?
#14 | |
Jesse
http://porterbuiltstreetrods.com/site/ |
#15 | |
Jesse
http://www.summitracing.com/parts/FLA-FR1503/?rtype=10 |
#16 |
Registered Loser
Mine lays frame but the pinch weld is still about 1/8" off the ground. With the PB x-member and 3" drop spindles you should be able to lay frame on 29.5" tires.
#17 | |
#18 | |
Jesse
![]() Progress wise im sanding and painting parts getting ready to install, its 103 here today so not interested in going out in the garage. |
#19 |
GM Addicted
Looking good and ahaha you must be around the valley somewhere this heat is getting bad. You should weight it all and see how much weight you lose.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#20 | |
I had the same thoughts on mine, keep it simple, didn't want the pump. Just curious if a rack eases the turn effort...factory GM stuff really builds muscle. Later. |
