06-12-2010, 07:18 AM | #1 |
Oil Pressure Gauge Not Working
I have a 86 swb, with a 305, A few months ago my oil pressure gauge stopped working. It would just stick at a pressure and "twitch" occasionally. A few days after that I noticed my sender was leaking so I replaced it but the guage never started working again. Any ideas?
06-12-2010, 09:56 AM | #2 | |
Still plays with trucks
Re: Oil Pressure Gauge Not Working
Just make sure you get one with the same range as the sender you are using. It will read wrong if you put an 80 psi gauge with a 60 psi sender or vise versa.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-12-2010, 12:23 PM | #3 |
Thank you, thats what I was thinking. Now another question, whats the best place to get a guage. Are they hard to replace?
06-12-2010, 07:13 PM | #4 |
The stock gauge has to have the instrument cluster panel, lens etc removed then the gauge should just pull out. It mounts into a trio of connectors (not sure what you call them).
Not sure where to get a bone stock replacement. Aftermarket would be the way to go in my opinion, of course then it wouldn't match the rest of your gauges. You might want to consider just relocating a mechanical gauge mounted under your dash.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 Last edited by 85Bowtie; 06-12-2010 at 07:19 PM. |
06-13-2010, 01:19 AM | #5 |
I really hate wet sanding!
Your local junk yard...should be dirt cheap and definitely not rare, if the new (replacement) fails to work, they most likely will let you grab another.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
