Old 06-12-2010, 01:53 PM   #1
indianajoel
67 Door window glass question
My window regulators on the driver's side keep going bad.
I just bought a brand new regulator and don't want to ruin it, so I was inspecting everything else and had a thought:
Is the left window glass different from the right?
Like if they are a little curved in towards the truck as they go up.
I put a straight edge on them and they are slightly curved - about 1/16".
but the right one is curved in towards the cab and the left one was curved away from the cab, with the convex side of the glass facing into the cab.
Could that be a problem causing my regulators to grind teeth?
or maybe the 1/16" is to small to be a big deal.
lmctrucks lists one door window glass without the frame -- no left and right side distinction.
My left side glass didn't seem to be seated all the way into the sash channel on one end, so that could've been what made the window tought to move.
Thanks for any advice.
-Joel
'67 C-10 250 c.i. 3-spd
'68 Dodge D100
'95 Dodge 2500 Cummins 4x4
indianajoel is offline   Reply With Quote
Old 06-12-2010, 08:41 PM   #2
67chevy1series
67chevy1series's Avatar
Re: 67 Door window glass question
no i got a 67 to but mine original didnt work that good either but then i oiled em up a little then they worked fine
67chevy1series is offline   Reply With Quote
Old 06-12-2010, 09:14 PM   #3
dan42
dan42's Avatar
I can't remember if the glass is different or not. Check the LMC catalog online to see if they have a RH and LH window glass - all the years will be the same. That shouldn't cause your regulator to be stripped, though - it's probably just old. There's a thread on how to rebuild wind wings the the FAQ section - it will be a good reference for you to make sure you are putting the window back together properly.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
