Old 06-12-2010, 02:20 PM   #1
C10Slim
Reverse Smoothie
Maybe a dumb question but, what the heck is a reverse smoothie? Does anyone have a pic of a regular and a reverse for comparison?
C10Slim is offline   Reply With Quote
Old 06-12-2010, 02:44 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Reverse Smoothie
no such thing as a reverse smoothie...
There either reverse OR smoothies
a reverse is a moon smoothie or rim turn backwards to give it a deeper look.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-12-2010, 04:45 PM   #3
Slow Build
Slow Build's Avatar
I think the reverse refers the the outer rim being turned around. If you'll notice in the link (bottom right) the reverse rims are flatter deeper into the wheel where as standard bevel into center earlier. The reverse wheels will have less backspacing though.
http://www.stocktonwheel.com/smoothies_wheels.htm
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-12-2010, 05:38 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
A smoothie is an aftermarket wheel which has no hubcap retaining bumps or clips showing when the hubcap is in place (like a rally wheel), and was originally designed to wear a compatible somewhat flat baby moon style hubcap. They also normally have a universal dual bolt pattern wheel center for both 4.5 and 4.75 bolt circles. A reversed smoothie simply has the center mounted further back in the rim providing a deeper appearance.
True reversed rims used a factory wheel center with either hub cap clips or hub cap bumps, which was cut free from the rim and turned around and welded in backwards (in a “reversed” position). When finished the hub cap retainers (clips or bumps) remain. Here’s a link explaining the process and visual benefits, starting at post #9. The link to RallyAmerica shows what a real reversed rim looks like.
http://67-72chevytrucks.com/vboard/s...highlight=rims
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-12-2010, 05:55 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Some people, like myself, refer to deep dish wheels as 'reversed'. Growing up with the 'lowrider' industry, if you had 'reversed' spoke wheels, then they were deep-dish.
Whereas if you were rolling on 'standards' the spokes were close to the outer edge, and therefore, made you NOT as cool....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-12-2010, 10:16 PM   #6
C10Slim
Thanks for the lesson guys! I guess deep dish would be the term I am most familiar with. That's what I am after is a deep lip so I guess a set of revers wheels it will be.
Old 06-12-2010, 11:45 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by C10Slim View Post
.... I guess deep dish would be the term I am most familiar with. ....
If you use that term, then some might think your talking about Pizza...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
