Old 06-12-2010, 04:06 PM   #1
WB72
Before and After
WB72's Avatar
Too much vacuum, brakes are sensitive.
Gents,
I recently rebuilt my engine with a cam that produces more vacuum than stock. The brakes lock up more than normal, is there a way I can reduce the amount of vaccum that goes to the booster in order to avoid the extra force on the brakes?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-12-2010, 07:45 PM   #2
JimKshortstep4x4
Re: Too much vacuum, brakes are sensitive.
What is the vacuum reading? Also, is it all four wheels that lock up or just the rear?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-12-2010, 07:53 PM   #3
msgross
msgross's Avatar
well, based on the venturi effect you could use a larger hose for the vacuum, this would slow down the amount of vacuum... in theory larger hose=less pressure/volume
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
