Old 02-15-2003, 05:32 PM   #1
Timbo
converting an original 72 to short bed
Do you think it would be a bad Idea to shorten an original 72 with the factory bigblock and A/C and stuff. Would you guys consider this to be ruining an original truck. This is my new project and I think it would be a lot cooler if it was a short bed. Just wanted some input.
Thanks, Tim
1995 Z28 383 stroker
1969 SS Camaro drag car project
1972 Chevy 402 BB A/C PS,PB, TH-400
Timbo is offline   Reply With Quote
Old 02-15-2003, 05:36 PM   #2
1971 Cheyenne
1971 Cheyenne's Avatar
it depends on your view of it, If you like it for the fact that it is a original, heavily optioned truck, then keep it. But the way i look at it, it's your truck, make it how YOU want it. If you really want a shortbed, shorten it it, it will still have the 402, and the AC.
my no sense
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 02-15-2003, 10:32 PM   #3
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i wouldnt i like lb myself but its up to you alot of people do it but if i was going to buy a truck and the frame was cut/or the vin showed lwb and it was a swb then i would not buy it
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 02-16-2003, 01:14 AM   #4
Piston
Piston's Avatar
I'll be cutting mine down this spring. But then... I bought another "Daily driver" LWB Fleetside for the day to day and occasional cruise-in's. The 71 LWB will be cut down and made into a SWB stepside. I've always wanted one and have never found the right deal.. so I'll just make one LOL.
If I only had one truck? I probably wouldn't do it.
Piston is offline   Reply With Quote
Old 02-17-2003, 08:41 AM   #5
STP67-72
STP67-72's Avatar
swb
I am going to do the same thing. 71 402 cheyenne, tilt and tack. It is probably worth about 5000.00 more when finished. I am going to use another frame. I think? If you plan on keeping it, cut it.
STP67-72 is offline   Reply With Quote
