![]() Join Date: Sep 2006
Some sort of bolt sleeve??
I was wondering if anyone has addressed this issue. I'm mocking up the rear bags with stock trailing arms on my '68. The long bolt that goes through the trailing arm is too small for the hole in the hole in the trailing arm. I've been looking for some sort of sleeve or something to go around the bolt to make it fit tighter, but haven't found anything. Anyone done something about this or do you just pull it down tight and not worry about it.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
low n' slo
![]() Join Date: Mar 2009
Re: Some sort of bolt sleeve??
is this the bolt that goes through the bottom of the ta to bolt to the bottom of the bag? let me check my build thread to see what size i used..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Yeah, that's the one. I've got a bolt that fits the bag, but the shank is too narrow for the hole in the ta. Leaves a lot of play in there.
low n' slo
3/8"-16, 4" long is what I used. no sleeve, worked perfect
Redefining LowBudget
you just need a washer over it
you get your air set up cleaned up?? I was looking in my tool box and ran across some of that trailer wire and thought of you... |
low n' slo
lol, ya i cleaned it up yesterday, works perfect. thanks again
i have a leak in my front driver side bag, but i think its coming from that bag fitting. i had a tough time getting the line to fit in there, awkward angle i guess. i posted a few pics in my build thread earlier..
