Old 06-12-2010, 06:57 PM   #1
Martin64
Martin64's Avatar
V8 radiator with an I6 engine.
Anyone done this?
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 06-12-2010, 07:04 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: V8 radiator with an I6 engine.
Could you be more specific as to your query? A V8 rad might have another row of cooling fins but I can't see it being detrimental in front of a six.
Old 06-12-2010, 07:22 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-12-2010, 07:56 PM   #4
Martin64
Martin64's Avatar
Well I'm considering a swap to a V-8 and the radiator I have in the truck is a smaller radiator for the I-6 as it's stock and I'm running the stock 230. At this point it's rotten and plugging up badly and needs to be replaced. The radiator for the V-8 in our trucks is larger. So in anticipation of swapping to a V-8 (more than likely a crate motor) I'd like to just put in the larger radiator now and not have the extra parts hanging in the garage later nor the added expense of another radiator.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-12-2010, 08:00 PM   #5
aerotruk63
aerotruk63's Avatar
Sounds good. I found in my 63 Service Bulletins that GM authorized dealers to step up to a 19" fan for clients who were complaining of running hot with the 230 six.
Old 06-12-2010, 08:08 PM   #6
2manyprojects
2manyprojects's Avatar
I put a new 66 327 automatic radiator in my 65 6cyl panel. It was a bolt in from what I remember.
2manyprojects is offline   Reply With Quote
Old 06-12-2010, 08:37 PM   #7
Martin64
Martin64's Avatar
Thanks for the confirmation guys. I didn't think it would be a problem but it's always good to get other views.
An added reason for going with the larger radiator is it's actually cheaper than the smaller one. The big one is $178 (and up depending on the parts source) and the stock one is $215 (and up).
Again, thanks!
Martin Gibson
USAF Retired
1964(-ish) C10
Old 06-12-2010, 10:22 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
If you're using stock parts, you may need the wider, upper radiator support......or fab one as usual!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-12-2010, 10:28 PM   #9
2manyprojects
On mine the tank was the same it just had 4 cores instead of 2. I can go measure it if you want? I still have the truck with the same radiator.
Old 06-13-2010, 07:27 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I had heard, that 63-65 they used the little tiny radiator with the 230, and then in 66 they used the big rad in all the trucks, which makes sense, my 66 with a 230 has the big rad, and my 63, and 64 both have the small one.
Old 06-13-2010, 11:56 PM   #11
Russ65C10
Russ65C10's Avatar
I'll second that one. My 66 that my dad bought new with 250 inline has the same exact radiator as my 65 with a 283.
Russ65C10 is offline   Reply With Quote
Old 06-14-2010, 12:08 AM   #12
Sixxer
Sixxer's Avatar
Maybe LILRED66 will chime in and give his expert answer but yes it can be done. I walked through the modifications today with him today actually... It seems fairly straight forward, you will need a v8 radiator, lower radiator mounts and upper radiator mounts, possibly two new radiator hoses and if you have a mechanical fan you will also need a cooling fan extender and some misc surround rubber to direct airflow correctly into the radiator. I will be doing this in the future because I'm adding A/C and don't feel comfortable with the cooling power of the factory inline 6 radiator.
Sixxer is offline   Reply With Quote
Old 06-14-2010, 02:18 AM   #13
LILRED66
LILRED66's Avatar
Hey Matt, thanks for the vine. It was good chatting with you this afternoon. Let me know how things work out on the brakes and if you can get the '64 to the shop. I will help you get the small radiator swapped over to the 3 or 4 core V8 radiator, shroud & saddles. Take care and good to see you posting.
LILRED66 is offline   Reply With Quote
Old 06-20-2010, 11:30 PM   #14
Martin64
Martin64's Avatar
Well that's what I'm finding out, same radiator height and width just more rows. I was thinking it was dimensionally larger, not just thicker.
Has anyone gone with an aftermarket "universal" and, if so, which one?
Martin Gibson
USAF Retired
1964(-ish) C10
