Old 06-12-2010, 09:51 PM   #1
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
and more brake issues
I recently converted my Jimmy to 2 wheel drive. I have new rotors, calipers and pads. The first few times I stop everything is OK. Then it appears that the left calper sticks engaged. Brakes get real hot. After cooling for awhile, they work great and then start the process all over again. Short of never using them, what do you suspect?
Thanks.
low'n slow is offline   Reply With Quote
Old 06-12-2010, 11:22 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: and more brake issues
Check for brake pad overlap. Seen it cause the pad to stick before, but usually on happens after a few miles are on the pads.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-12-2010, 11:34 PM   #3
low'n slow
low'n slow's Avatar
What is brake pad overlap? it has about 15 miles on it.
Old 06-13-2010, 05:58 AM   #4
cdowns
cdowns's Avatar
do you have a proper disc/drum master cyl and proportioning valve assy? using a drum/drum srtup will cause the calipers to bind up and overheat
if they overheated you need at least new pads and to check calipers for warping
Old 06-13-2010, 08:05 AM   #5
LONGHAIR
Did you replace the rubber lines? There have been issues with them collapsing internally, causing random dragging
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-13-2010, 10:16 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
If it only has 15 miles on the system then pad overlap is not a concern.
To answer your question, pad overlap is when the pads are glued on the backing plates to far outboard. As the wear, a portion of the pad remains intact protruding out from the worn pad surface. This can cause your pads to stick to the rotor and not release.
Articles-
"Refining Sierra"
Old 06-13-2010, 11:59 AM   #7
low'n slow
low'n slow's Avatar
Yes, I have the proper master cylinder and proportioning valve. All new steel and rubber lines.
Old 06-13-2010, 06:12 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
adj. rod OR (i had an extra gromit betwen booster/mc causing brakes to stick)
John
1999 Toyota Tacoma 4x4
Old 06-14-2010, 07:12 PM   #9
low'n slow
low'n slow's Avatar
If the rod was too long, wouldn't it cause to brakes to drag all the time? This only drags after the brakes are used a few times.
Old 06-14-2010, 07:38 PM   #10
raycow
If the rod was too long, both sides would drag, not just one. There is a similar thread running on the 67-72 board right now, still not fixed. Look for "At my wit's end".
I suggested checking for bent pins (that the caliper slides on). Haven't got an answer to that post yet.
Ray
raycow is offline   Reply With Quote
Old 07-03-2010, 10:44 PM   #11
low'n slow
low'n slow's Avatar
The rod was too long. I shortened it, freshened up the brakes and all is well. Thanks for the help
