06-12-2010, 10:11 PM | #1 |
12 Bolt Rear End Gear info needed!
Hey yall, im in need of a 3.07 or 3.08 gear for my 71 c/10. ...i have a 3.73 or 4.11 now. will a 3.07 or 3.08 fit the carrier i have now?
1971 Chevrolet C/10 ShortBed 1978 Chevrolet K/5 Blazer 1986 Chevrolet Silverado ShortBed Last edited by N2TRUX; 06-12-2010 at 11:51 PM. |
06-12-2010, 10:22 PM | #2 |
Parts and more parts
Re: 12 Bolt Rear End Gear Needed!
Suggestion from some experience that I have attained over my life. I recommend a new set, vice used ones. It takes a reall good rear end guy to get the gears aligned back to the same grooves that they originally run in at. If you don't get them back in alignment, you may have some rear end noise. Been There--Done that.
Frank |
06-12-2010, 11:38 PM | #3 |
In short, no. The differential case break on the 12 bolt is between 3.42 and 3.73. It's been my experience that if you have to buy gears and pay someone else to set them up, it is generally cheaper to buy a complete rear that has the ratio you want.
Ray Last edited by raycow; 06-12-2010 at 11:40 PM. |
06-13-2010, 01:32 AM | #4 |
Re: 12 Bolt Rear End Gear info needed!
You will definitely need the corresponding carrier. I have done this many times and have never had a issue, don't use mixmatched gears, use only a known set (GM), a carrier from another set is fine as long as it is the right one and I don't use any of those ring gear spacers, new crush sleeve with proper torque, and use the shims (put them back in the same locations), bearings, and of course bearing caps out of your existing housing, new bearings have never been a problem but don't mix new bearings or races with old ones. I have a old Chilton manual from the early 70's that shows how to check the gear mesh pattern and gives a backlash spec if you want to check it just find one of these books, from experience checking backlash it always sounds and feels like alot more than it really is. I have done this many times and have not had a problem yet, with the exception of a corvette with aftermarket gears that required shimming but that was to be expected. Knock on wood but I haven't swapped a whole housing yet because of gear ratio. Just my $.02 worth.
06-13-2010, 06:10 AM | #5 |
the cheapest way is to find a complete rear out of a parts truck
06-13-2010, 08:40 AM | #6 | ||
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
