Old 06-12-2010, 11:52 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
ls swap fuel pump ?
when I attempt the ls 5.3 swap I plan on using a external mount fuel pump, so if it does work how big of a pump do I need, also I already have a 87 tbi fuel tank so what sender would I need
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-13-2010, 12:43 AM   #2
pcmcobra
pcmcobra's Avatar
Re: ls swap fuel pump ?
If you already have an 87 tbi tank, get an 87 tbi sender, and get an "in tank" walbro pump and be done with it. Will fit right in the sender, hook up your wires and hoses, burn rubber.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-13-2010, 04:02 PM   #3
flamingbig10
6.0 powered square
but I want a external mount pump for easier fuel pump replacement
Aaron
Old 06-13-2010, 05:08 PM   #4
pcmcobra
pcmcobra's Avatar
then stick with your stocker, dont need the 87 stuff.
