2 barell carb. HICCUP???
After buying new plugs and wires and adjusting the fuel mixture I get an awesome idle. The problem is when I hit the gas, the engine brfiefly accelerates then hiccups then continues to accelerate. It is worse when I am in gear and driving. I used to have a high idel and no acceleration problem. What do you guys think it is??? Oh yeah it starts on a dime now too so I dont think it is the fuel pump, but maybe?
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
Re: 2 barell carb. HICCUP???
Check accelerator pump shot in carb, look down the carb with engine off, and pump the throttle slowly, you should have a steady stream of gas in the carb, if not then the pump sleave on the inside is damaged, or there is junk down in the pump well impeading the flow.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Great, had it rebuilt last year so I didnt even think of that but you are probably right.
Resistance is Futile
I think Rich 5150 69 is correct; or the pump needs an adjustment. The engine needs the extra fuel to compensate for the air when you press the accelerator.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
