Old 06-13-2010, 12:41 AM   #1
Pont406
Cutting hood?
I am very close to driving it. Need to do something with a hood. Nothing wrong with original hood. I don't know how long I'll keep this set up. Whould you cut original hood or try to find another one first?
Pont406 is offline   Reply With Quote
Old 06-13-2010, 12:54 AM   #2
woodwright
Enjoying left field
woodwright's Avatar
Re: Cutting hood?
Take the hinges off and run it like that.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 06-13-2010, 01:00 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Cutting hood?
x2
John
1999 Toyota Tacoma 4x4
Old 06-13-2010, 01:00 AM   #4
hayhauler71
hayhauler71's Avatar
Re: Cutting hood?
x 2 no hood look good
hayhauler71 is offline   Reply With Quote
Old 06-13-2010, 01:07 AM   #5
mstrav1973
mstrav1973's Avatar
Re: Cutting hood?
I see most run it without hood and hinges, just hope you have a car to use in the rain. If your hood is really nice, you might want to find a cheap one to practice your cut on if you are going that route. That motor looks mean!!! nice job.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-13-2010, 05:22 AM   #6
72shortstep
lovin' the lowcountry
72shortstep's Avatar
Re: Cutting hood?
No hood, or see if someone has a hood with a big nasty dent in the middle... Make sure there are no low flying birds around when you stomp the gas, haha. looks awesome!
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 06-13-2010, 07:00 AM   #7
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Cutting hood?
Don't cut up a good factory hood. Get a fiberglass one or as stated a dented one from a Recycler.
Truck looks good by the way.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-13-2010, 07:13 AM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Cutting hood?
Agreed!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 06-13-2010, 09:48 AM   #9
88fordf150
88fordf150's Avatar
Re: Cutting hood?
How about alittle more info and pictures of the truck? I have a 69 also and am planing on a blown 454. Got the motor done but the truck is still in a pile.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 06-13-2010, 09:57 AM   #10
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Cutting hood?
I guess my 2 cents.......don't cut the original hood if it's the same color and in good shape. Just be prepared....cutting the hood on these is a nightmare on elm street. The rear brace is a challenge. With that said, I think some cars/trucks have the lines to look good without a hood. I don't think these trucks are one. I ran mine for awhile without a hood and then realized this is not 1985.
You can forget about fiberglass too. I did quite a bit of research on that. You can get some race weight hoods that will be a pain to get on and off by yourself. You almost have to pin it unless you want a huge hole to cover the swing forward they have. Plus....you have a fire and everything will be toast before you can get it off.
prostreetC-10 is offline   Reply With Quote
Old 06-13-2010, 10:08 AM   #11
Andy4639
Old member
Andy4639's Avatar
It want matter if it's Fiberglass or metal if it catches on fire. You aren't just going to lift it up like a factory. I'd rather have the Fiberglass than a full metal one to lift off. I don't think you could do a tilt on this one but it may be a option.
Old 06-13-2010, 10:53 AM   #12
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Cutting hood?
Could you split a hood down the middle and hinge it on either side so it opens that way?
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-13-2010, 10:57 AM   #13
scooterskoolkustoms
scooterskoolkustoms's Avatar
Re: Cutting hood?
I say no hood ,why hide that engine,SHOW'EM WHAT YEA GOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 06-13-2010, 03:17 PM   #14
tasian
tasian's Avatar
Re: Cutting hood?
if your not sure your going to keep the setup i'd go with a beater hood for now
i've always heard it isn't legal to go hoodless in california
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 06-14-2010, 12:31 AM   #15
Pont406
Re: Cutting hood?
I got it going. Couple small issues. Minor oil leak and only 3 psi of fuel pressure. During short drive I kept on looking at shifter indicator. It feels like its in second gear. I should of done this install sooner. Next trip is a dyno shop before I start beating on it. Pulleys set up for 6 psi. One thing I noticed is that a blower can hide a cam. I am running a little over 250 at .050 duration, solid cam and idle is smoth.
No hood for now. Thanks.
