Old 06-13-2010, 09:16 AM   #1
Greg63
Enjoy your truck
Greg63's Avatar
Newer OEM rims on our trucks - 6 bolt pattern
Are there any factory 6 bolt rims from newer trucks/SUV's that will bolt up to the stock 6 bolt pattern of our trucks?
I like the look of the SSR rims but was told they wouldn't fit. From what I have read, the 6 bolt pattern is the same but the bore is different.
I would like to see what would bolt up without expensive machining.
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 06-13-2010, 09:48 AM   #2
Blue666
Re: Newer OEM rims on our trucks - 6 bolt pattern
Not sure about the SSR (new Trailblazer type) rims but you will need to order spacers to get newer full size rims to fit on a pre 87 six lug hub. I found a great source on Ebay but it will take me a while to find him on my old computer.
There is also a bit of a deal about going from hub centric to rim centric.
Think I used a 1.5" thick spacers on all corners. Trying to get a picture to load.
Blue666 is offline   Reply With Quote
Old 06-13-2010, 12:51 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I believe the Trailblazer bolt pattern is not 6x5.5''. But yes, the bore on the newer wheels is smaller. I dont remember exactly, but its in the neighborhood of a 1/4'' smaller.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-13-2010, 01:27 PM   #4
Blue666
Here is my truck with the 2000 Tahoe wheels. I used a 1.5" space on each corner. Tires are BFG 235/70 r 16. The truck has a 3 inch drop spindles & 4 inch lowering springs.
Old 06-13-2010, 03:13 PM   #5
Greg63
Enjoy your truck
Greg63's Avatar
A 1 1/2" spacer really puts the rims on the outside of the corners.
What is the cost of spacers vs. machining the rims?
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-13-2010, 03:40 PM   #6
Greg63
Enjoy your truck
Greg63's Avatar
This is what I was thinking of, but there are so many other OEM 6 bolt rims to choose from now.
Any other pictures of rims installed on our trucks?
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-13-2010, 05:30 PM   #7
spankbomb
Hmm, I wondering about this, too. I have a bunch of the 17" steel wheels and I was wondering if they would work on the older six lug pattern...
www.eastofaustin.com
spankbomb is offline   Reply With Quote
Old 06-13-2010, 09:52 PM   #8
Slow Build
Slow Build's Avatar
I'd love to see what the Silverado SS wheels would look like on our trucks (with shorter tires than in pic).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-13-2010, 11:34 PM   #9
apachedaddy
apachedaddy's Avatar
I had a set on my 66 with a 1.5 spacer. Even with the spacer i could'nt put the center caps on the front due to the dust cap. Hope this helps some.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 06-14-2010, 12:11 AM   #10
Slow Build
Slow Build's Avatar
Got pictures?
Past GM Trucks:
Old 06-14-2010, 08:24 AM   #11
Blue666
I did not check the cost of machining as I needed a spacer so I could get the center cap to seat.
Old 06-15-2010, 10:02 AM   #12
Steve Van Gent
Steve Van Gent's Avatar
These are the spacers I bought. http://cgi.ebay.com/ebaymotors/1-5-W...Q5fAccessories
I think I actually got 2 inch for rear....
Steve Van Gent is offline   Reply With Quote
Old 06-15-2010, 07:04 PM   #13
Bulldoser65
I have thought about putting the wheels off my 04 Yukon onto my 65 and getting new wheels for the Yukon. But not sure I want to mess with the whole hub problem and spacers.
Bulldoser65 is offline   Reply With Quote
