Old 06-13-2010, 09:47 AM   #1
taclem
taclem's Avatar
Accelerator Pedal Travel
Just installed a carpet kit yesterday, it looks great, but I don't have full accelerator travel. Only opening up about 1/2 to 3/4 full throttle. What is the best way to increase this and get back to full use of my 292. Thanks, taclem
taclem is offline   Reply With Quote
Old 06-13-2010, 03:37 PM   #2
C10Slim
Re: Accelerator Pedal Travel
Stock or aftermarket pedal? Most aftermarket have spacers you can purchase to lift it up of the carpet 1/4" - 1/2" and get the travel back.
C10Slim is offline   Reply With Quote
Old 06-13-2010, 04:34 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Shorten your throttle rod, assuming you have a somewhat stock set-up.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-13-2010, 06:29 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Would that not be to lengthen the rod as to push the gas pedal back and rotate the carb linkage more?
Old 06-13-2010, 08:32 PM   #5
protrash64
protrash64's Avatar
To push the gas peddle back, you need to shorten the rod, pulling the link forward in the engine compartment and pushing the peddle out in the cab.
I'm thinking of my Quad BBC combo, I guess it depends on where it hooks to the carb.
