When setting up the air bags to weld the mounts etc. Do I want the bag completely compressed or just half way or? I am talking about the rear.
In other words would I want the bags to have medium air at about ride height or would my ride height bag be completely filled for a better ride. Is there a preference? |
Re: Do I set up bags at lowest compression first?
Set it up at ride height.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
Set them so there about half to 3/4 filled at ride height. You need to know the total stroke of the bag. If your running fully inflated it will be a rough ride.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
as long as the bag isnt riding against itself when your driving you'll be good. So whatever it takes to keep the folds of the bag from rubbing eachother is where you'll want ride height to be...
I always set it up so that the bag is fully compressed when the vehicle is at it's lowest point. That way you get the maximum travel available from the bag.
Yellow truck club
With my f9000 bags from ART they have specs. for them.
You should try to find the installed height of your bags which is also the ride height and work from there. mine was 9"-9.5". THey usually have a max height and min. as well.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#8 | |
However, it depends on where you want your truck to be at ride height. 4DSEVEN, what bags are you planning to use? In place of the coils? or where? |
I have Dominator 2500 & 2600 bags. I am currently setting up the triangulated 4 link but figuring the bags will be over the axle.
This is also what I do when setting up bags. I set them fully compressed so that I can make sure I get full travel when inflated. Keep in mind, that I do this when the truck is laying frame. If you set the bag mounts with the bag partially inflated, unless you do all the math on the bag and the height of your frame, when deflated, the bag could keep you from laying out.
Redefining LowBudget
your bags are 2.8" deflated with a 8" extended so do your mathe and check your travel but the key is going to be your ride height ..you dont want the bags running to high or low
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#12 | ||
It was mentioned to try not having the bag overlap each other when at ride height. Is that the consensus? Say about 2/3 at ride height? I have purchased the Autopilot controller and hope to have pretty much a ride height setting, in the weeds and up higher for speed bumps and driveways. Am I going in the right direction? Last edited by 4DSEVEN; 06-22-2010 at 10:20 PM. |
#13 |
I have never heard of anything regarding this. I don't think it would be an issue.
#14 |
I dont think the rubbing is an issue I would move the bags to the front of the AXle to gain the most leverage and most lift/drop but it might be tough with a tri 4 link
#15 |
Got the rear bags set up and they came out perfect. The truck sits on the ground in the rear so far.
#16 |
Looks great! Where are putting the shock mounts?
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
