Old 06-13-2010, 11:52 AM   #1
nac593
major distributor issues!!!
I have 14,000 miles on everything new. I replaced EVERYTHING in the engine compartment. ( and most of the rest of truck. $20 k invested.) The distributor keeps goin out. At around 5000 miles it wouldnt start. Had no spark. I replaced the ignition module and coil in the HEI dist. It started right up. The same thing happened at around 8000, 10000, and 12000 miles. Every time I replace the module and coil it starts right up. Today it wont start AGAIN!!! I talked to an old time mechanic that said I have a constant voltage going to it when truck is off but I checked voltage and its zero volts. He told me to go back to points. Where is a good place to get a points distributor? and yes the ground strip is in the distrib and i used dielectric grease. Any help or ideas?
nac593 is offline   Reply With Quote
Old 06-13-2010, 12:03 PM   #2
zeeklu
Re: major distributor issues!!!
You did replace the old wire going to the distributor?That's all I can think of. Chris
zeeklu is offline   Reply With Quote
Old 06-13-2010, 12:04 PM   #3
nac593
yes i relaced the old wire
Old 06-13-2010, 12:04 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Yeah, make sure you're getting 12 volts to the HEI.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-13-2010, 12:09 PM   #5
nac593
checked it and i am
Old 06-13-2010, 12:13 PM   #6
292farmer
292farmer's Avatar
whats the motor?
292farmer is offline   Reply With Quote
Old 06-13-2010, 12:54 PM   #7
nac593
It's a 350 crate motor. 290hp. bought a chevy distributor
Old 06-13-2010, 01:17 PM   #8
mbgmike
Did you replace it with a GM module or aftermarket. Some of the Aftermarkets are junk and will do that.
Also make sure you don't have excessive current to the Module
Excessive current will increase the temperature of
everything in the circuit. If a circuit fails in the module it can damage a coil and the coil will fail often. Likewise a partially shorted coil can destroy or damage modules.
Aftermarket ones do not always have the current limiting that they should have.
No need to go back to points. Need to check all voltage drops with a scope
mbgmike is offline   Reply With Quote
Old 06-13-2010, 01:25 PM   #9
nac593
I've replaced with napa parts and kragen parts. I've bought the cheap ones and the spendy ones. I think last time it was $45 for each part. That's $90 to fix one time. And I've fixed a few times. This is ridiculous and frustrating. I have spent hundreds of dollars. What about going to points?
Old 06-13-2010, 01:33 PM   #10
Captain Underdog
When they say make sure you're getting 12 volts, they really mean 13.8 - 14.2 volts. Nothing runs on 12 volts unless it would be your old points coil. What kind of alternator are you running? Does it have a remote sense wire? or is it "one wire". To diagnose this you should hook a good voltmeter to the HEI power wire and drive the pickup. Watch for voltage spikes when you shut the lights/wipers/etc. off. Watch for low volts when running with all the accessories on. The HEI needs a consistent 13.8-14.2 volts.
Oh, and don't go back to points, if you are frustrated now you will learn to hate points.
"..not ashamed of the gospel" Rom. 1:16
1968 C10 (newly acquired)
1967 Checker Marathon (waiting for paint)
1968 C50 Service Truck (resting in peace for now)
I need another project like I need another hole in my head!!!
Captain Underdog is offline   Reply With Quote
Old 06-13-2010, 01:41 PM   #11
nac593
I bought a new altenator from kragen. Its the newer style that doesnt use the voltage regulator mounted on the radiator support. I will try your advice but I need to get the truck running again! I am sick of breaking down and spending all that money to go a couple thousand miles! The wife wants me to sell it because of the problems. I replaced everything on the truck to make sure it"s reliable< but it keeps breakin down
Old 06-13-2010, 01:56 PM   #12
cdowns
cdowns's Avatar
do you have good clean bright and shiny ground connections everywhere that is needed?
Old 06-13-2010, 02:03 PM   #13
vectorit
What?
vectorit's Avatar
I wouldn't go back to points, but if you are ready to scrap the HEI... Then look at Pertronix.
Seriously though, the HEI shouldn't be going out that often.
Have you taken the rig to an automotive electrical specialist? Rather than throw money away at parts, take it to a specialist and describe what is happening.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-13-2010, 02:15 PM   #14
Captain Underdog
I'll say it again; check the voltage supply to the HEI under driving conditions. We are running lots of newer electronics on an electrical system that wasn't designed to provide the power that the electronics need. A bigger/newer alternator like you already have is a good start, however the system must be wired to provide a consistent share of that power to everything that needs it. If your voltage supply to the HEI is fluctuating the cure is pretty simple and easy to do.
Old 06-13-2010, 02:16 PM   #15
mbgmike
I doubt if its the alternator. You don't need to keep buying parts. Need to check for voltage drop with a scope. These problems generally lie in the coil and module. You need to know what it is
Old 06-13-2010, 02:23 PM   #16
nac593
I have redone All gronds and extra grounded everything. I know it shouldnt go out that often and thats what is frustrating. I took it to an electrical specialist for a different problem and it was kinda a joke. They just replaced parts until fixed. I coulda done that. I will take the advice of checkin voltage when running but I need to get it running again.
Old 06-13-2010, 02:36 PM   #17
mbgmike
Here is a good article.
http://rmcavoy.freeshell.org/HEI.html
Old 06-13-2010, 02:39 PM   #18
Captain Underdog
That's the beauty of forums like this; we usually do better than throwing parts at it. If you can use a scope like mbgmike says, that would be best. A scope is just a voltmeter displayed on a time line so you don't miss anything. If you don't have access to a scope just use a volt meter with a friend watching it as you drive.
If your pickup is wired like mine from the factory you will have to change some supply wiring to get consistent supply volts to everything. It's easy and simple. Take heart, you are almost done with this problem for good.
Old 06-13-2010, 02:39 PM   #19
mbgmike
I agree. You want full voltage to the HEI. need to remove any resistor wire that would be preventing that and replace with non- resistant wire
Old 06-13-2010, 02:47 PM   #20
nac593
thanks for the help so far. I did remove the original wire with resistor and replaced with new wire
Old 06-13-2010, 02:53 PM   #21
dan42
dan42's Avatar
X2 - goofy crap happens when you are driving around - that's gotta be it. I'm having issues with my retrosound radio (that's been replaced three times) and it's probably the same type of issue - getting a surge from something.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 06-13-2010, 03:05 PM   #22
nac593
I dont understand if i'm getting wierd voltage while driving, how come it runs fine and than wont start. Is it burning out the coil and module? Wouldnt the truck die when running?
Old 06-13-2010, 03:06 PM   #23
mcbassin
Still Learning
mcbassin's Avatar
This is a strange situation indeed. I replaced my points setup back in 87 right after I got my 70. Originally I didn't even run a new wire, never had any trouble with it other than changing plugs and wires. Probably put about 50k miles on it daily driving to work. I am still running the original alternator setup.
I wonder if you are getting a spike like stated earlier?
mcbassin is offline   Reply With Quote
Old 06-13-2010, 03:07 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
How's your battery? does it die when your coil and module die? Just curious if it still has voltage to it after you kill your truck?
Old 06-13-2010, 03:15 PM   #25
mbgmike
Is this a factory Hei distibutor?with spark control
You can check the module to see if its working by
disconnecting the 4 wire terminal from the module to
the esc if you have one.
If you have good power from the distributor
it should spark
You can pull the distributor out give it power and ground and spin it by hand and it
will spark if the coil and module are good.
